JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
Who or where do I find FORscan in Jersey? I wanna unlock Sport
Alpha1_Silverback
AARON
Ohio
21' Bronco Badlands
Mike1976
Fort Collins, CO
05 GX470
I can confirm. Tonight I added all missing GOAT modes (Baja, Rock Crawl, Mud and Ruts) to my BaseSquatch and drove a bit in each one successfully with no codes.
Have you seen any issues or codes since you programmed your BaseSquatch? I picked mine up at the end of last week. Waiting on Amazon to deliver my OBD cord since I lost my last one.
djn3400
Cleveland
Bronco BaseSquatch, Chevy Suburban, Kia K5
None what so ever!
Dark Knight Squatch
Jack
2014 Ford Police Interceptor Utility
None what so ever!
Could I ask what USB-OBD you're using? I have a basequatch as well and I'd love to add the additional goat modes.
Also have you tried using baja? Curious to see how that works given it uses sway bar disconnect.
djn3400
Cleveland
I used this:
OBDLink EX FORScan OBD Adapter
I have used all of the modes with no issues or codes. Including rock crawl and baja which use the stabilizer disconnect. This was my main concern, but everything works fine.
Dark Knight Squatch
Jack
I used this:
So awesome to hear! I’m gonna be ordering the adapter then I’ll figure out how to work forscan before I do anything
BroncoAZ
Mitch
2021 2 Door Badlands manual, 2021 Tacoma TRD OR
There is a very good post about the Magnussen Moss act on the tacomaworld forum that many people should read. The net is that Ford has more lawyers and money than you do, and it can be hell to get a denied claim overturned. Unless @Ford Motor Company post on here and says this forscan mod to add goat modes is ok and won’t effect warranty claims down the road then completing the mod has risk. I would like to see some official guidance from Ford on the warranty issues of simple programming like removing double honk, adding fog lights with a factory switch, double press on the panic button, or other convenience mods.
FFS Let's all stop referencing the Magnussen Moss Act......
I've seen a lot of chatter on the forums about the Magnussen Moss Act. Mainly about how to use it to intimidate a dealer (or the manufacturer) into performing warranty work on modified vehicles.
Now I've got a bit of a problem with this - primarily in that despite what you wiki about "The Act", employing it is a different beast altogether.
In 2003 I purchased a Mini Cooper S to use as a track car. I immediately set to modifying it. New coil over suspension, new cylinder head and camshaft, new custom exhaust, new BBK, new intercooler (I eventually even twin-charged it).
With about 8K miles on the clock, it began exhibiting some odd idling behavior and some electrical gremlins associated with the ECU. My first thought was that it was related to the cams and the new engine management system. However everything was checking out.
By coincidence I took it to the dealer for an issue with the lock on the rear hatch. One thing led to another and they explained to me that there was a TSB that deals with a manufacturing flaw with the portion of the wiring harness that connects to the throttle body. They asked if they could keep the car to perform the TSB.
The TSB essentially called for replacing the entire wiring harness. A $200 part but a 10 hour job. As they began the work, a local manufacturer's rep stopped by, saw the mods to my car and told the dealer to stop working on the TSB.
The dealer immediately notified me and I stopped by. The rep was still there. To the dealer's credit, the service manager explained that my mods had nothing to do with the known failed part in question. The PUMA rep, in front of me, told the dealer to stop working on my car - as the manufacturer would not reimburse them for any work.
Two years prior I had been made a partner in my firm, and we had a team of excellent lawyers on retainer. I contacted one of the partners in the law firm and he immediately got things rolling. This eventually led to my lawsuit against the manufacturer in which I alleged they violated the M-M Act.
My lawyer hired a mechanic who removed the wiring harness and proved that it suffered from the manufacturing defect affected by the TSB. My lawyer also hired forensic mechanics who, when deposed, proved that the modifications could not have caused the KNOWN ISSUE, and he even hired a legal expert on previous M-M Act lawsuits who would testify as to the illegality of refusing TSB work on an issue already recognized by the manufacturer as a defect on a vehicle under warranty. Things were looking up. The manufacturer was blundering along, my lawyer was bitch slapping them at every turn....
Now never mind that this process was costing a lot of money. At this point it was about principle - plus we were going to ask for judgment in which the legal fees were reimbursed.
That's when reality set in.
One rainy afternoon my lawyer called and said that we had our first M-M hearing date in federal court. I dry-cleaned my only suit and away we went.
I'll spare you all the gory details, I'll spare you the legalese.....the defendent countered all my facts and all our prep with one simple move - they motioned the judge to have my car entered into evidence as it WAS the evidence in the case. The judge agreed. In five minutes, the manufacturer had literally prevented me from driving my car until the case was settled.
The second move that the manufacturer did was to ask for a delay until the next hearing. The judge agreed.
The third move that the manufacturer did was to ask for court-mandated mediation. The judge agreed.
My lawyer protested on all counts. As a consumer, essentially robbing me of my car for months, possibly even years was contrary to the spirit of the Act. The manufacturer countered by saying that the car WAS the evidence and they needed to make sure that it was not further tampered with. They also needed time to perform their own evaluation of it. They even offered to split the costs of this impoundment with me!
My lawyer made the point to the judge that we were getting caught up in needless procedure and minutia....that the manufacturer was on record through deposition stating that they had denied warranty work solely due to the fact that the car was modified. That they had admitted at the same deposition that the warranty issue was so severe that they had not only issued a TSB for it, but a pending recall was in the works.
The judge was not swayed. Car was to be locked up as evidence, we were to go to mediation (which costs a shitload of money) and that the manufacturer was granted delays to gather more information.
At this point my lawyer and I stopped for lunch. He says, look, I've worked on this for free so far....and if I was charging you, you'd be about $12K in the hole. I'll represent you for free in mediation, but until there is a verdict, mediation is split 50/50 and one day will set you back $3500. This is for $1400 worth of fucking work.
I said let's try one day of mediation.
Mediation consists of a neutral lawyer trying to convince both parties that they are fucked and don't have a case - so that they agree to meet in the middle. The manufacturer played pocket pool for 8 hours and then promptly asked or a second session in 90 days time.
At this point, I had enough. The car was impounded, I had just spent $3500 to get satisfaction on a $1400 issue and by all rights probably owed my lawyer $15K. I told him that if the manufacturer supplied the new harness, I'd install it.
They eventually agreed and the dealer actually stepped forward and installed it for me (I had a long history with them).
Since that time (in 2015) the manufacturer actually settled with the FTC for long running violations of the MM Act.
https://www.ftc.gov/news-events/pre...arges-its-mini-division-illegally-conditioned
The take away for all you armchair quarterbacks and lawyers is this:
The M-M act is a piece of paper. You are not going to scare any dealer or manufacturer with it. To actually get to the teeth of the Act, you need to litigate it. That costs time and money. Big corporations with legal staff on the payroll are not burdened with the same costs as you are. While you're spending $5K or $10K or more, all they are doing is continuing to pay the salary and benefits of people they already have on staff.
Second, judges are laymen...what seems common sense and cut and dried to you, is probably not so to them.
Third, the object of the lawsuit can be entered as evidence. Which means no mall crawling with your spacer lifted Bro-Taco for months.
My advice? You pay to play. If you mod, there is always the risk that some asshole dealership under threat from corporate may give you a ration of shit. If that happens, Googling "Magnussen-Moss" and waving it in their face is only going to make you look like the naive dip shit that you probably are.
Lastly, for the love of all that is Holy, as a rule we should all stop giving advice on things we have absolutely no fucking experience with and only limited and borderline retarded knowledge of. If we did, this forum, if not the world would be a measurably better place.
SogBecks
Matt
Delano, MN
I used this:
Since we're sharing, just throwing this out there as an option too. I got it on a Lightning deal for $50:
https://www.amazon.com/gp/product/B07JFRFJG6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Best part, it's wireless. I did have connections issues using this with Forscan at first, but read somewhere else on the internet that I needed to install the OBDLink software: https://www.obdlink.com/software/
Once I did that, launched it and used the software to connect to the Bronco first, all subsequent connections via Forscan have worked flawlessly and successfully made the change to enable Sport.
mpeugeot
Rock Crawl and Baja work perfectly in my OBX.
Dark Knight Squatch
Jack
I used this:
If you don't mind could I see a picture of your ABS module on forscan? Im a bit confused by the instruction video since that's only adding sport mode and I'm trying to add the 3 missing modes on base, I figured I would just copy how you did it
