Front Hitch Capable
Toccoa
Isuzu Rodeo Sport
Is this your Plan B for when it breaks down? 😁
Ford Bronco Front Hitch Capable 1618454228831
MaverickMan
Shane
I plan on either modifying the modular bumper to accept a winch or just making my own bumper so yeah I'd say welding on a reciever should be easy enough. Did the same thing to my comanche although a lil uglier than I play to do on the Bronco.
AcenTitus
Peter
MO
Erock
US
2018 F150 Alpine edition
Planning to build mine as well, for a winch. Or are you referring to a hitch for flat towing?
da_jokker
Jeep Wrangler JKUR
I'm hoping, but doubtful that some aftermarket will make something that can bolt onto the existing factory bumperS (maybe to the recovery spots) that will allow for either a reviever or at least a winch.
But chances are we'll have to buy a whole new bumper.
North7
North Texas
SUV
BR0NCO
Randy
Mass
Jeep Audi
The nice thing about a front hitch mounted winch is that it sticks out so far that with it installed you will be bashing it into things long before it lets you get into a situation where you would actually need a winch.
da_jokker
Jeep Wrangler JKUR
I actually did just that on my XJ... Installed a front hitch for either the winch or a bike rack. Worked out good..the main issue was simple that I had to plan ahead to hook it up. So those last minute explorations or trying to help someone else when needed didn't work out because my winch was (and still is) sitting in the garage.
North7
North Texas
SUV
Some of us will not install it, until needed, problem solved.
North7
North Texas
SUV
FINALLY - a sensible human. Now just put this connector on the front and back:
That connector looks good but I'm concerned about the silver contacts, however the connector looks similar to the Warn and Bulldog ones. Those do not list the contact type of finish. The safest bet is the standard boaters trick, always coat all your electrical connector pins and connections with dielectric grease, including 4 and 7 pin trailer light connectors or winch connectors. Otherwise, moisture will tarnish the contacts and you will lose electrical connection or reduce your amperage due to resistance.
https://www.warn.com/quick-connect-power-cable-32963
https://www.etrailer.com/Accessories-and-Parts/Bulldog-Winch/BDW20207.html
https://www.amazon.com/Permatex-811...words=dielectric+grease&qid=1618494310&sr=8-6
Ford Bronco Front Hitch Capable 22058
