Gaia Freezing Issue???
Does Gaia lock up for you when going into reverse or changing apps?
  • Total voters
orion
Jeremy
17' F-250, 17' Explorer
Do any of you that have Gaia Maps have the issue of it freezing/locking up when going into reverse or when changing apps? It seems like any time the SYNC screen is changed from Gaia and back, it locks up.
I'm using a Galaxy S10 & Android Auto. Has anybody had this issue and fixed it?
FstFrd00
www.gunsmithingtx.com
2021 BD Sasquatch
Freezing or is it still running but the touch screen is unresponsive?
I've never had it completely freeze on me but the touch screen has been unresponsive at times. On wireless AA, S22+, T-Mobile
orion
orion
Jeremy
I'll post a video of what mine does when I get home tonight. T-Mobile here too.
Hopeless Diamond
JR
Chumstick, WA
F350/2dr Rubicon/'96 4R/'02 Silverado 1500/'22 Badlands
Off-line maps or drawing them down as needed? Gaia has been acting wonky for me the past few days, both on devices and on my PC
Jdc
Jon
Massachusetts
Bronco Badlands
I've had a couple of apps get a little wonky on me lately. Might be related to an update. I fixed them both by going into the app settings and clearing both the cache and app data. I don't have Gaia but that'll more than likely mean you'll have to login and download your maps again.
climb2descend
CA
15'F150
Any updates on this? I was having this issue this weekend, also on Android, I would keep having an issue where the gpx route would disappear off the screen and my location would also disappear, it would show just fine on my phone, I would have to keep plugging and unplugging the cable from my phone to get this to work, really annoying. Also had the same issue with reverse would throw it out of whack.
orion
orion
Jeremy
Nope, hopefully an update fixes it. I do however run the app on my phone while it's going in android auto and that seems to help a little. Doesn’t freeze as much...
akturbo
Seattle Eastside
I finally figured out last year that Gaia must be the primary open app on the screen on both the phone and the Bronco, otherwise, the app is mostly locked up. I've reported this to them but others need to complain.
Hopeless Diamond
JR
Chumstick, WA
I've used Gaia as a road map on a couple of long road trips recently, not for navigation per say, just to have a decent map up on the screen to watch routes and the general area. I have found that it's possible to get the location marker back if it disappears by going back and forth with full screen, jumping over to the Ford Nav (which I think really sucks), eventually it comes back - maybe. I set up wireless charging pad and it can't quite keep up with it, phone will get hot and start shutting down apps, although Gaia could still be running on the screen. I need to try it plugged in via USB and see if that will keep up with the charging and maybe not be so flakey.
Speaking of flakey, have been trying the Bronco app as a general map, needs internet of course, but how about this. Somehow I had that up on the main portion of the screen and then Gaia running on the far right portion of the screen at the same time. Both showing location and tracking. No idea what I did to get that
Ford Bronco Gaia Freezing Issue??? 20230506_075303
