Ham Radio Install Done
Liquidtravel
Layne
Canyon Lake, Texas
2022 Bronco
I finally got my radio and antenna set up and running. It was a lot easier than I thought. I routed the antenna cable through the floor and side trim in about 20 minutes to get it to the front and under the dash. I put the radio above the glove box/ under the dash. I then routed the mic behind the infoscreen to the driver's side, where I hung it on a drive-side molle panel . Then, I put the radio controller up on the dash using a 1" ball mount. Lastly, I pulled out the grommet between the engine and cabin to cut it for the power cables, which was pretty easy to do. Overall, I am pretty happy.
Equipment
Ford Bronco Ham Radio Install Done PXL_20240509_200951832
Ford Bronco Ham Radio Install Done PXL_20240509_201336384
Ford Bronco Ham Radio Install Done PXL_20240509_201344676
Ford Bronco Ham Radio Install Done PXL_20240511_003518270
Ford Bronco Ham Radio Install Done PXL_20240511_003533624
n5mj
Carlsbad, NM
'22, '93 Bronco '97 Ranger '03 Sport Trac '11 SHO
Nice work! Thank you for the links.
Assuming you have the rear window defroster, how does the antenna SWR measure up?
de N5MJ
STEED77
NoVA
12 JKU
Nice Clean install... well thought out. How is the VSWR?
Rocky905
Rob
Boulder County
2023 BADLANDS non-SAS
Equipment
Really nice summary, and appreciate the “materials and source” list. WC0R
Liquidtravel
Liquidtravel
Layne
Canyon Lake, Texas
2022 Bronco
de N5MJ
Yes, I have the defroster. I don't have a SWR meter so I can't check. I plan on getting one in the future.
Mrplowjr73
Kory
New York
22 BD SAS
Nicely done! I know it won't matter quite as much for VHF/UHF, however those mounts do not ground well at all. I ended up needing to run a separate ground and grind down some of the paint/powdercoat of the mount in-order to get an SWR under 3.2 on HF. As soon as I cleaned under the mounting bolts and where the antenna goes through the bracket I was down under 1.4 (close enough for government work)
MtnTopComms
Brandon
Klamath County Oregon
2012 Audi Q5
Very nicely done.
Brandon
AE7BF
