Hard top roof water leak
carrellslake
Oregon
2022 Ford Bronco
Has anybody else had a leak like this one? Only on the passenger side, and part of it is coming off the side window.
Ford Bronco Hard top roof water leak BE3DA4E9-23DF-438F-AF1D-C5574977902E
Ford Bronco Hard top roof water leak 6809B571-FA56-4634-9098-23E23AD9D34F
Kfonte
Kris
Miami
Audi
I’ve had light leaks at the car wash and on light rainy days twice before. Funny enough, a tropical storm and heavy rain days I don’t get anything. I can’t seem to find the issue but it definitely started happening after I took the top off. I have a 2dr.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi Kris. Can you send us a DM with your VIN and dealership info? I can look into this for you.
Pilsner
JTR, 81 Bronco, 21 BD
I had a lot less noise after removing and reinstalling the MIC panels. They did not appear to be installed correctly from the factory. Have you have yours off?
carrellslake
carrellslake
Oregon
2022 Ford Bronco
I have taken mine off a couple times. One noise problem with my roof is the weatherseals over the doors aren't long enough from the factory. I'm trying to get my dealership to replace those seals but that's been slow going.
Mike Kleen
Alabama
2022 EG Base MIC
I just had my first leak today after just 3mos. I haven't had the top off in over a month. I'm thinking the cool weather contracted some seals but who knows.
jaypee
Josh
Louisiana
2022 Bronco
Reviving this thread... I just started having the exact same issue after one year. Just curious if you were able to fix it or did you have to end up going to the dealer?
2022 base
john
AZ 85143
1991 Chevy, 2004 Cooper S
I just had the same issue with my 2 door. I never had my top off. There are cracks in the top above my rear pass side window. I called the dealer and they will have it for a few days to start the warranty process.
Quest
Massachusetts
2023 Ford Bronco Black Diamond 4DR
Had this happen for the first time a week ago and then a second time a couple days ago. I've had the thing just over a year now. Seems to occur only when some g forces shift it somehow like pulling out of a parking lot. Both times it is from the top on the windshield area. First time was about center in front of the passenger, and second was near center of the vehicle. Popped the front two panels off and found it was wet between the panel and the main front gasket....
BitterBronco
Connecticut
2014 Tuxedo Black Ford Edge
Yeah I’ve had this same problem. Seems like a common issue for the roofs (so common that I don’t know of a Bronco hard top owner who doesn’t have the issue after a year of ownership)
NC_Pinz
Central NC
2022 Ford Bronco OBX w/ Squatch, 1975 Ford Bronco
Pretty broad statement. I've had mine for almost 2 years and no leaks.
BitterBronco
Connecticut
Certainly - I don’t know all Bronco owners, of course. Only a handful in New England and the Midwest. Enough of a sample size that I suspect that outdoor storage during winters (a few thermal cycles) or removal of the top is likely all it takes to make a crack around those windows.
Hdscreens
Will
2dr Bronco Badlands
Mine has always leaked. I figure if I just place a towel to soak in water I can live with it.
