Help sourcing wire and cable
Phil B
Phil
Plano Texas
2023 Bronco Wildtrak
I have a Anker alternator charger to install in the rear of my Bronco. I want to run parallel wires to install a power bus in the cargo area. Where can I find the cable for this? I'm looking for cables already in a loom. Not sure of the wire size yet, thoughts on that? A fuse and Anderson connector at the battery would be a bonus, those will be part of the install.
I have also been looking for 10 gauge solid copper primary automotive wire, preferably black and white paired.
I already have cables run for other accessories and an amp so I may have to go down the passenger side because I'm out of room on the drivers side. I've removed my plastic trim, molle panels, shelves, etc. so many times already. I'm hoping I can plan this out so I don't have to do it again anytime soon.
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
Try Powerwerx.
You don't want solid wire - that stuff is really hard to work with., especially with the larger cable sizes. Stranded is what you want (and more strands are better - more flexible and higher current capacity, but quality crimps become much more critical)
All of the above are good sources. Convention for DC power is Red (+) Black (-), white (N) black (Hot) are convention for AC power -- but there's no law that says you must follow that, just that the black color gets somewhat confusing if you hand it off to someone not familiar with how it installed.
SierraBronco
A hexagonal crimper changed my life when it came to girthy wires.
I have an inexpensive hydraulic one I use for anything bigger than #10, and it was cheaper than a set of pre-crimped cables. Much easier to run cable when it doesn't have ends on it already, and don't have to worry about trying to tie up excess cable somewhere - can custom-cut everything to fit.
Some crimpers are brand-specific, and you need to use the correct lugs with the crimper. Just pay attention to what you are getting. I have a Thomas&Betts ratcheting crimper that is like that.
I do need to get one for stupid connector pins, I don't have a proper crimper for those yet.
SierraBronco
I just picked one of those up. Have yet to use it though.
23_Badlands
US
'25 Tacoma Limited, '23 Bronco 2d SAS 7sp(AB) High Tow Modular Hoop
I have also been looking for 10 gauge solid copper primary automotive wire, preferably black and white paired . . . .
If you go this route, measure very, very carefully. We have a full assortment of cable, wire, looms, terminals, connectors and various hydraulic crimpers in our garage and it's still takes some doing to get things to fit right.
Not sure which model Anker you have. Some of these Anker units are rated around 60-80a. You mentioned using 10 gauge wire. If your Anker is one of these 60-80a units, 60-80a exceeds the ampacity of 10 gauge wire. Depending on the length of your run, I personally wouldn't use anything less than 4 gauge, ideally 2 gauge.
CalvinT
Calvin
Phoenix, AZ
CalvinT
Calvin
Phoenix, AZ
I run rope over the planned route then measure the lenght of the rope before ordering wire.
23_Badlands
US
For smaller gauge wire this may work. For larger gauge *cable* with their limited bend radius, not so much.
indio22
Chicagoland, USA
Do you or anyone have a specific recommendation on a budget crimper model? I need to get one for my 4 gauge amp power wire install. Reviews of various models online are all over the map.
Also when selecting wire, another thing to consider is the type of sheathing. Specifically some outer sheathing stinks ... literally. I've got a nose like a bloodhound and have had to return several items due to smelly plastic off gassing. Unfortunately it's difficult to know if rubber/plastic stinks until giving it the sniff test.
Phil B
Phil B
Phil
Plano Texas
I'm installing the 800 watt alternator charger that was just released. It comes with it's own wiring harness to the battery. The 10 gauge is for power to other things. (That may attach to the power point I want to build.)
Phil B
Phil B
Phil
Plano Texas
I'm an (all trades) ICC certified building inspector. Picky about my builds, and know a few things about wiring. I would like to make the power point for 100 amps. That's probably more than I would ever need, 1/0 wire is large to run and expensive. On the fence about running #2 or #4 instead.
