Holes (mounting points?) on rear of roll bar?
Bschurr
NY
I liked your setup so well that I just ordered an Element and 2 magnetic mounts. Did you PPF the section of roll bar?
I used 3” wide clear UHMW tape under the mounts - it’s thicker and more durable than PPF.
FYI - I also used it on the door sills and on the portion of the rollbar that may contact the soft top during opening/closing to prevent scratching there too.
Peter Gosenya
Gabe
Atlanta
Now we know what these are for.
PootsBronco
Jack
Flagstaff, AZ
2013 Silverado 1500
The bronco raptor has an additional brace in the back that looks like it bolts into those holes, so my guess is that what the holes are for. My build is a 12-18 blend and both sides have holes, my guess is that as the bronco raptor gets closer the builds will be more consistent in having them on both sides.
Ford Bronco Holes (mounting points?) on rear of roll bar? Screenshot_20220128-204909_YouTube
Ford Bronco Holes (mounting points?) on rear of roll bar? Screenshot_20220128-204902_YouTube
UtahBrandon
Brandon
www.puravidaoffroad.com
a number of classics and my 4dr Badlands
You made me go outside and look. Left and right are the same and they look like Raptor bar mounts on my 10/29 build. Not sure about the center hole or the inboard threaded holes though.
Ford Bronco Holes (mounting points?) on rear of roll bar? 8A69F4BC-6C7A-4A7A-B5FD-9EC0E1493982
Ford Bronco Holes (mounting points?) on rear of roll bar? 8140FFA7-BCD3-4C7C-88C9-98BEFDE2191C
wedemmoez
Moez
Dallas
2021 Bronco Badlands, 2007 Porsche Cayman S
Anyone know what the thread pitch/size is for these holes? Havent been able to find documentation for it anywhere. Wanting to 3d print some hooks to hang my rock climbing gear from them
Bschurr
NY
M8 1.25
VelocityBronco
E
wilbersk
Sean
2023 Bronco Raptor
My Element is on the rollbar
Ford Bronco Holes (mounting points?) on rear of roll bar? PXL_20211130_193546043
And a flashlight on the seat rail
I’d switch those two spots. You want a fire extinguisher to be really close if a fire was to break out.
Bschurr
NY
Roger123
Roger
VA Beach, VA
Repost from other thread, but interesting:
So I had to go outside and check. I have a 2 door Wildtrack, built 7/23, them again 10/23 and I have what appears to be a pretty beefy threaded mounting hole, maybe ½" in diameter on the top rear of each roll bar, left and right. Just one hole each. Hard to tell, sorry for dark pics, I'm parked for the night against the back of my garage wall and didn't want to move my truck.
Ford Bronco Holes (mounting points?) on rear of roll bar? 9F809E41-E519-4799-AD3A-C106B03ECBA6
Those holes aren’t threaded. No idea what they’re for?
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
I just noticed this today that my left and right bars going down into the cargo area are different.
Right side:
Left side:
Nothing! Weird. So what do yours look like? Anyone have nothing on either, or holes on both?
I remember reading a post about this awhile back. Search for it...i cant remember the resolution.
wedemmoez
Moez
Dallas
Johnny Mo
Westchester County, NY
teachu2shoot.com
Ford Fusion Energi, Ducati XDiavel
I guess with the c-pillar cross bracing from the Raptor - we know what these holes are for now.
