How to disable seatbelt chime
B-Rad
Brad
Morriston, FL
1968 Bronco 1978 Bronco 2021 Bronco
I couldn’t find this anywhere so I figured I’d post it. If you have a big dog riding shotgun or are driving around on your farm where a seatbelt isn’t needed and the seatbelt chime is bugging you it is easy to disable.
1) Sit in the seat you want to disable the chime for. (you will have to do it individually for all seatbelts you want to disable)
2) Push the ignition button with the key in the truck and without pressing the brake pedal. (So the ignition is on without the truck running)
3) Wait for the seatbelt light to go out.
4) As soon as the seatbelt light goes out buckle and unbuckle the seatbelt 3 or 4 times until the seatbelt light comes back on.
5) Buckle and unbuckle the seatbelt one last time, the seatbelt light will flash a few times letting you know you did it right.
iamchewby
Chewby
Do this every time? Or does this work forever?
BennyBronco69
Gordon
BWM M4
BigFootie
Wisconsin
2013 ES-350, 2022 Badlands Sport, 2023 Heritage Ed
Nice, I just unplugged the seat. Didn’t know this trick.
Strange how they set these things up. Had to set up new key fobs in the Escape. Similar trick, off and on 8 times, hit the lock button on the door, then the lock button on the fob. Presto, new fob is connected!
I wonder if you can do something similar for the auto start/ stop.
B-Rad
B-Rad
Brad
Morriston, FL
I think this works on all new fords I did the same thing to my 2018 F150’s and 2021 Ranger
B-Rad
B-Rad
Brad
Morriston, FL
FYI it does not work on the back seats (but it doesn’t really matter because there are no seat pressure sensors in the back of a 2 door, 4 door might have them so it might work on a 4 door) When I pulled my backseat out I had to leave the seatbelts in place and plug them back in or else I got a seatbelt an airbag light But the seatbelts hide perfectly underneath the carpet
MooreNC
Charlotte NC
2016 JKU , 2017 Explorer Sport
Thank you. I have been looking for this, works perfect.
NVCowboy
William
Henderson, NV
I’ve always equated this process to trying to say yes while shaking my head no. However, backing up to trailers or backing trailers is a bad time to have the truck screaming at me. Damnit, I know I’m not belted in! I’m in on this wheneverthehell Bronco arrives.
pitviper68
Columbus Ohio
2002 camaro
works for a 2013 f150 too.
bloominguez
Tom
Atlanta, GA
'22 Br BD, '22 5BW, '95 Integra, '94 VFR, '04 SV
Kudos to Ford, by the way, for having this procedure. Not all manufacturers do. I want to unbuckle and get the mail before I drive up the driveway without my car yelling at me.
RalBronco
Honda
I would just like to say thank you for posting this. That seatbelt chime was starting to drive me insane.
‘21OBX
90Bronco19
2022 bronco outer banks
Trevor
Gilbert,Az
Bronco raptor
This doesn’t seem to work for the raptor. Anybody know a work around yet?
