how to disable traction control / advancetrac permemnantly {fusebox solution}
Desert runner
FAL
Saudi Arabia
bronco'21 /Raptor'22 / Silverado 2500'22
I have a problem with the traction control/advancetrac.
it hinders the vehicles performance in the sand/snow, i was recovering a vehicle with a heavy load i couldnt reach the angle i wanted due to the traction.
I have made some research into how to disable the fuses but couldnt find anything.
Has anyone figured out how to disable it through the fuse box permemnantly like our friends in the raptor forums?
or is there a way to disable it through forscan or any other permenant way?
Tricky Dick
Dick
PNW
www.TD-Distributing.com
It also works really well in snow/ice in certain situations. I haven't come out of 2wd in weeks and our roads have been iced over the whole time. The disable hero switch is the best of both worlds.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
Does the export model not have the disable switch on the hero panel? Should be the last one on the RH side
Theherofails
Thomas
Phoenix
Hold down the traction control button on the hero panel for 7 or so seconds… unless you’ve tried that already.
Desert runner
Desert runner
FAL
Saudi Arabia
I do know how to disable it from the hero switch but it still kicks in.
I am trying to disable it completly without it kicking in after a certain speed or when in sand,
The vehicle thinks you are drifting when in realtiy your just going over a dune and the back end of the vehicle has to lose a little grip the traction kicks in and ur throttle is limited and cant raise the RPM.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Are you sure you are pressing and holding for seven seconds with the Advancetrac disabled pop up (vs the traction control disabled)?
In my experience so far - snow vs sand, which won’t matter - press and hold completely disables the feature as expected
Desert runner
Desert runner
FAL
Saudi Arabia
i am disabling both traction and advancetrac through hero/traction switch and holding it for 7 secs untill the pop up adcancetrac disabled screen shows up, it still kicks in when the vehicle loses traction example if your going up a sand dune or going down one.
I had a sitation where my CV axle started clanking so i disabled 4H and the baja mode and had to switch to 2H for the remainder of the trip. the car is fully capable of offroading in sand without 4H we were going around 150-200 miles in the desert on a 3 day trip.
I couldnt fully switch off the traction always kicks in and in 2H u need traction completly off to be able to not get stuck due to limited power in the throttle.
The issue is when the traction kicks in no power can be sent to the wheels , got stuck 3 times due to the traction.
would really appriciate if anyone has a solution through removing a fuse. the toyota's who were with us in the trip have a separate fuse that is removed to disable the traction completly even though theres a button to disable it, it also kicks in.
In some situations you need it permanently off
Soundgarden
The Dude
Northern Canada
Bronco Badlands-Suburban 2500
i dont have a solution but confirm that even when you remove advanced traction completely, it still kicks in whenever theres a moderate slipping condition and its annoying.
Tricky Dick
Dick
PNW
Interesting. I tried a bit today in deep snow in 2H with traction control off and couldn't get it to activate no matter how sideways I got.
Spooled
Republic of Texas
Had this issue with my F-150. Only way I could get it to do a proper burnout was by unplugging a wheel speed sensor. Even with traction and advancetrac turned off if would pull power after seeing a certain wheelspeed.
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
You could try Fuse #23 in the engine bay - ABS system. Perhaps you'd trick the computer that way? Not sure what affect it would have on traction control, but you could give that a shot?
AK SNO RIDER
Ty
Alaska
Nah, even "fully" disabling advanctrac still results in it constantly kicking in when it's slick out. It drives me insane.
