I am going to go to my Bronco now and see if I can help.Thank you!
I also found this, but my menu do not offer this option
- Go to Settings > Press the menu button
- Go to Vehicle Settings > Press the OK button
- Go to Locks > Press the OK button
- Go to Intelligent Access > Press the OK button
I do not have "locks", I can show you a picture next week.
Ich habe gerade nachgeschaut un konnte nich finden, wie es geht.Your German is perfect, much better than my english
Ja die haben da einiges verändert. Obwohl es ja ein US Auto ist, das nur importiert wurde. Das fängt schon bei der Fernbedienung an. Die hat nur auf und zu und die anderen buttons fehlen.
Aber vielleicht kann man das über forescan abschalten. Ich brauche es nämlich nicht und habe keine Lust immer die Schlüssel in Boxen zu tun. Die klauen bei uns regelmäßig Autos mit keyless entry.
Broadcast Message | Originating Module | Message Purpose |
Vehicle speed | PCM | The BCM uses the vehicle speed data for the autolock and auto-unlock features. |
Door lock switch status | DDM / PDM | Provides the BCM with lock/unlock requests based on the input from the door lock control switch. |
Message center feature configuration | IPC | Provides the BCM configuration settings selected by the driver of the vehicle, such as autolock and auto-unlock settings. |
Action | Status of Door(s) | Status of Hood | Visual/Audible Feedback |
Press the lock button on the door lock control switch | Open | Closed | A short flash of the turn signals after all the doors are closed. |
Press the unlock button on a RKE transmitter | Closed | Closed | A long flash of the turn signals. |
Press the lock button on a RKE transmitter | Closed | Closed | A short flash of the turn signals. |
Press the lock button on a RKE transmitter | Open | Closed | A short flash of the turn signals after all the doors are closed. |
Press the lock button on a RKE transmitter | Closed | Open | A short flash of the turn signals after the hood is closed. |
Press the lock button on a RKE transmitter twice within 3 seconds | Closed | Closed | The horn chirps twice and the turn signals flash twice. |
Press the lock button on a RKE transmitter twice within 3 seconds | Open | Closed | The horn immediately chirps twice and the turn signals flash twice after all the doors are closed. |
Press the lock button on a RKE transmitter twice within 3 seconds | Closed | Open | The horn immediately chirps twice and the turn signals flash twice after the hood is closed. |
LED | Status |
Blinking green | Waiting for status update from vehicle |
Blinking red | Remote start/stop failed |
Solid green | Remote start or extension successful |
Solid red | Remote stop successful (engine off) |
We are talking about disabling this:I'm very confused. Are we talking about just disabling the fob from locking/unlocking the vehicle?
The easiest way, since you do not have the option like other Broncos, would be to simply just unplug the door handles. Unless there is a quick forscan option, but I have no knowledge of that.We are talking about disabling this:
"The passive entry feature unlocks or locks the doors and the tailgate without having to use a mechanical key blade or the RKE transmitter feature."
At the German/ European software version, I have no option to disable this function. I want to disable it.
