How to program a Ford Accessory keyless entry pad to a Bronco?
tongsun3717
X3
I bought a keyless entry pad for my Base Bronco. I thought the manual should tell me how to program the pad to the Bronco, but only saw what follows that step: adding personal 5 digit code. Please help me of you know how to link the pad to the Bronco. Thaks a lot!
Burgler2112
Andrew
NJ
2022 Black Diamond Bronco 2.3l Mid Soft Top
You need to take it to the dealer for them to pair it to the Bronco.
sucks but apparently it’s the only way.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
It has to be programmed in FDRS (Ford Diagnostic and Repair System).
To use it, you'll need to buy a support J2534/VCM II/VCM III USB dongle that is approved for use by FDRS (several hundred dollars to a few thousand, depending on the dongle), and you will need to buy a license for the software. Licenses range from $50 for a 2-day license to $900 for a yearly license.
OR, as @Burgler2112 mentioned, pay your dealer to program it for you. Takes all of 5 minutes.
RagnarKon
Bryan
New England
To use it, you'll need to buy a support J2534/VCM II/VCMM USB dongle that is approved for use by FDRS (several hundred dollars to a few thousand, depending on the dongle), and you will need to buy a license for the software. Licenses range from $150 for a 2-day license to $900 for a yearly license.
Here is a writeup @mpeugeot wrote on how to do it.
https://www.bronco6g.com/forum/threads/how-to-add-a-keyless-entry-the-supereasy-edition.51446/
Beach_Bum
Ken
St. Augustine, FL
RagnarKon
Bryan
New England
Thanks for digging it up. I knew he did a write up that is why I tagged him.
Lol no problem, I was trying to dig it up as well but the search function on this forum software is absolutely horrific so I didn't include it in my first post. To my surprise, found it shortly after I posted.
Scott R Nelson
Meridian, ID
Why not just have the dealer take care of it? That's what I would do if I were in your position. I very much like the keypad that Ford installed at the factory. I guess someday the battery will die and I'll have to get another one, then I'll be going through the same issue.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Dealer technician needs to program it. I don't know why but I guess that's the only way to do it.
tongsun3717
tongsun3717
X3
Thank you, everyone!
