- First Name
- Emil
- Joined
- May 1, 2023
- Threads
- 0
- Messages
- 8
- Reaction score
- 2
- Location
- Dominican Republic
- Vehicle(s)
- Ford Bronco
- Your Bronco Model
- Black Diamond
My sub is a powered JBL BassPro NANO , ans is pulling its signal from the kick panel speakers.14F1 needs to be either 2AF1 (Sp, TW, Sub) or 02F1 (Sp/Sub). I'm assuming your sub is pulling its signal from the ACM, so you need to use Forscan to activate it.
You also want 727-01-02 to be "00"...turns off the high pass filter in the pods. Ford's EQ setting sucks.
EQ Settings - ACM 727-01-02
- xxYY-xxxx-xxxx
- 00 = EQ Off
- 01 = EQ On (High-pass filter on the rear pods)
