Tina
Tina
San Diego, CA
2022 Ford Bronco 2-Door
I made this release handle out of paracord so that I can get out from the inside of my Bronco rear swing gate.
Ford Bronco How to Make an Emergency Release Handle for Inside of Swing Gate 6bL09QI72IAo3bMWk4D9NBfpoVi96MOjHXExWhMyH-ebuFtNIA
Recommended Tools & Supplies
  • Plastic pry tools
  • Four (4) inches of wire, or anything you can fashion into a flexible sorta needle, I used 22 gauge craft wire.
  • Small needle-nose pliers
  • Something skinny with a small hook on the end, I used a loop turner for sewing. You could probably use a hook and pick tool set too.
  • Twenty (20) feet of paracord, I used PARACORD PLANET 275 LB Tensile Strength Paracord Rope for the inner cord and PARACORD PLANET 425 LB Tensile Strength for the outer cord. (You may not need this much.)
  • Lighter
  • Paracord FID or something metal to push ends through when done and smooth out singed ends. I used a pair of large pair of tweezers (again from my sewing kit!)
Ford Bronco How to Make an Emergency Release Handle for Inside of Swing Gate 7YaNAlBn-lfy97qoExvYvSGJSJbmcFTYPvCTdwm82xHDQSuIBw
Follow these steps:
1. Use the pry tools to remove the tailgate trim panel.
Start on the left side, the left side has the clips, and the right side just slips out once the clips are popped out.
2. Remove the inside release lever cover.
3. Using the small needle-nose pliers, find the release lever (just so you know where it is. It's very hard to see).
Ford Bronco How to Make an Emergency Release Handle for Inside of Swing Gate pX-syLGpOp1AStZCWQqHrRuMQr49sk32gELFPBvwEOO3w8HdCQ
4. Fashion your wire into a flexible needle with a small loop at one end.
Ford Bronco How to Make an Emergency Release Handle for Inside of Swing Gate oQBdG3uLjT0e2UXnnLjqLFwAsFKT0s6NoVYqvBVorBrFNcfZkA
5. Poke the other end through the end of your inner paracord, and squeeze it closed to secure.
Ford Bronco How to Make an Emergency Release Handle for Inside of Swing Gate dtm6wT5JVyMeaA0Fhgf5Ij9ZuNTLfkDSq8qrFbadKaxMBMP0
6. Feed the loop end of the wire through the hole in the release lever.
This is the tricky part, but I swear there is a hole in there!
7. Once you get the wire through, use the loop turner or hook to grab the loop end and pull the paracord through. It helps to push lightly from the paracord end while pulling it through from the other end.
Success! At this point, I closed the tailgate to check that it worked, with the window open, of course!
Now that you have your paracord through the hole, you need to determine the size of your loop. Pull enough paracord through until you have two strands, equal length and long enough to form a simple loop plus a couple of inches. I used about 60 inches total but 30 inches as it is doubled on itself.
8. Tie a regular ā€˜ol knot just at the end of the lever ā€œtunnelā€ to keep it all tidy.
Ford Bronco How to Make an Emergency Release Handle for Inside of Swing Gate dTcY1FWz11LMLczSgghc9ApIpihKmYdHaRjFQ3T04mMDsB5jIA
9. Feed the loose ends through the tailgate trim panel.
Ford Bronco How to Make an Emergency Release Handle for Inside of Swing Gate ilbA8xTRK0OpHozE0dW6pHHPJslovYiu7FPtK25WB2htxDz39w
10. Replace the trim panel by sliding the right side into place and pressing the left side clips into the swing gate.
11. Fashion the cord into a loop handle as you please. I used a cobra knot, but this was my first time using paracord, so not sure I could explain it as well as the zillions of videos on youtube. I liked Bored? Paracord! and Paracord Planet videos.
UPDATE: Be sure the loop is thin enough to tuck back into the trim panel to avoid accidental or nefarious openings!
12. Once you are done, just pull the handle along the tailgate, as shown below.
Donā€™t pull straight away from the tailgate. It wonā€™t work and may damage the lever.
Ford Bronco How to Make an Emergency Release Handle for Inside of Swing Gate sB5Dw9NhJPt8sPr65rQVHVkGDZQJX5CTQKoAc6tef1R3-5d1rQ
This is what is happening when you pull the cord:
Grayeti
Greg
Illinois
Pontiac Vibe
Very nice! Great idea too.
GaryB2220
Gary
Wellsboro PA
Good idea!
jdawg
Julian
NewHampshire
Atlas/65Mustang
Awesome. Even looks good. If the door is locked, does it still open?
BroncoB
Christine
Tampa Fl
Bronco First Edition
I donā€™t know why Ford doesnā€™t include release levers for these kinds of things. I had to fashion a handle (out of paracord) to release the latch of the driver side rear seat back on my F150 screw so I could get behind it and utilize the space.
604Bronco
British Columbia
www.bronco6g.com
It's not mandated by law, since it's not a "trunk" and that would cost them money, is my guess.
Great write-up, OP!
Before doing this cargo door release setup, @Tricky Dick found himself trapped in the back of his Bronco like...
Ford Bronco How to Make an Emergency Release Handle for Inside of Swing Gate giphy
JPye
Alberta canada
2012 BMW X5
If Ford included something like this it would be pretty easy to open the rear hatch with a coat hanger slipped between the glass and hatch. I wonder if doing this when the doors are locked will trip an alarm.
CashOfLegend
Washington D.C. Metro
2022 Ford Bronco, 2009 Honda CR-V
great now they can escape...Good Job!
Tina
Tina
Tina
San Diego, CA
something your dog can trip while romping around in the back?
This is an excellent point! My dog rides in the backseat but I'm glad you mentioned it for others!
Tina
Tina
Tina
San Diego, CA
Hmm, haven't tried it. Iā€™ll get back to you.
Lifeliberty
MoonbeamšŸ‘€
Columbus, OH
Maybe less likely to snag if it's 2 tails instead of a noose
You got me thinking, i might use my garage door emergency handle and cord(removed because theives)
