I Just had my Bronco rustproofed with Noxudol 900.
Darrell
Darrell
Maryland
I just had my Bronco rustproofed with Noxudol 900. It was done at Automotive Protection services in Fairfax, VA. I'm just wondering if anybody else has done this. Here's a description
Rustproofing involves applying cavity wax (similar to Fluid Film) inside the upper sheet metal of your vehicle. Once applied, it seals out air and moisture which contributes to the formation of rust. We apply our rustproofing cavity wax inside the door panels, rocker panels, tailgates, trunk lids, and inside the hood.
Our rustproofing cavity wax is an impressive product that, along with regular maintenance, will ensure a rust-free body for your vehicle - the product is backed by a ten-year written warranty by Noxudol.
If you'd like to protect your vehicles upper sheet metal against the formation of rust there is no better option on the market today than a Noxudol cavity wax application.
Noxudol 900
Noxudol is a superior line of undercoatings and rust-proofing products manufactured and engineered to provide excellent protection to all motor vehicles. For decades Europe's leading automotive manufacturers have relied on the advantages of Noxudol products to provide unrivaled rust protection on their new vehicles. The combination of Noxudol cavity wax and Noxudol 900 working in concert to protect your vehicle's exposed metal is unrivaled in the marketplace.
Ford Bronco I Just had my Bronco rustproofed with Noxudol 900. tempImage9RgSt8
Ford Bronco I Just had my Bronco rustproofed with Noxudol 900. tempImagenPZtEK
Ford Bronco I Just had my Bronco rustproofed with Noxudol 900. tempImagevqlCY
Ford Bronco I Just had my Bronco rustproofed with Noxudol 900. tempImagezHVOOt
Darrell
Darrell
Darrell
Maryland
Sorry for all the pics but i cant seam to remove them
2112
Fox island
F350 GT500’s FGT MACH I Z8
I can see the advantage of doing the frame rails and undercarriage bits Ford leaves bare.
aren’t the body panels galvanized or aluminum and more resistant to corrosion?
LS2GTO
Gene
Tennessee
05 gto 00 f-250 03 t-bird 70 chevelle 59 tr-3..
I might consider that but per their website their isn’t anywhere near me that applies it.
2112
Fox island
I am really interested in this for the undercarriage and tubular framing.
unfortunately, no installers outside the northeastern US.
Ford Bronco I Just had my Bronco rustproofed with Noxudol 900. 638811FA-6C5A-4A82-8740-F51C9B78CEF1
indio22
Chicagoland, USA
Have any owners noticed yet, if water tends to collect inside the Bronco frame rails? That has been a longer term problem for some 4x4s, notoriously with the Jeep TJ frame rails, which caused rusting from the inside out. (In fact I drilled some drain holes in my Jeep TJ frame to prevent water collecting inside.) Hopefully the Bronco frame does not have that issue.
2023bronco
usofa
2023bronco
I recently got an estimate from them, for Noxudol $600 and $175 for cavity wax.
The thing I've been wondering about is whether the cavity wax is necessary, considering that the doors, hood, and front fenders are aluminum. It would seem most helpful for the rear quarters, which apparently are steel.
The same place also offers Woolwax for $450.
Something I read about the Noxudol is that it's a lot more to contend with when working on the vehicle, in terms of removing it from nuts/threads. But of course that should mean it lasts longer than Woolwax too.
OP, can you post more pics for us?
Darrell
Darrell
Darrell
Maryland
Thats why I drove 70 min. to get to it, nothing in Maryland
Darrell
Darrell
Darrell
Maryland
your right but I thought for an extra $175 what the hell.
2112
Fox island
yeah, that’s reasonable. I would too. I wish we had trained applicators out here.
2112
Fox island
Noticed they stayed off the CV shaft.
