I need mud flaps, whats everyone using?
W2s2008
Wade
Wisconsin
2023 big bend
I would like to add some flaps but want to see what's out there. Thanks!
jacknifetoaswan
JR
Charleston, SC
2016 Mustang GT/PP
mj63
Matt
Toledo
Rallyarmor
Ford Bronco I need mud flaps, whats everyone using? PXL_20230314_222739166
SumBronco
2012 Jeep GC
Not trying to hijack the thread, but has anyone tried the IAG I-Line mini mud flaps yet? Im also looking at mud flap options and wondering if they work at all. (Did a search and didn't see any reviews.) Thanks!
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I had the Gatorback mud flaps on my Bronco - They were awesome! Just took them off yesterday for some new rock sliders I installed. The nice thing about these too is you can remove the bottom portion very easily, to regain some ground clearance while off road.
darinhouston
Darin
U.S.
Bronco, Jeep Wrangler, Bronco Sport, Pallisade
I need something easy to put on and off during a ride - don't want them on daily drives, don't want them at obstacles, but want a deep and wide one for gravel on trails.
timhood
Tim
Several
So, the first question is Sasquatch or not? Flaps that fit Sasquatch will stick out past the flares on non-squatch. I've been looking for a good set that doesn't have a bunch of brackets and is designed to fit Badlands with rock rails and non-squatch. II think I've found two options and will probably pick one and try and if they aren't great or end up fitting for Sasquatch, return and try the other. I'm only planning on putting on the front for now, but I'll get the full set in case I change my mind.
Southside_Ray
Ray
Iowa
2014 Ford Fusion
Agreed with post before mine. Need more information to make any recommendations...
I have the Rek Gen Merica flaps on my Sas. Tons of rock chips on my rear fender flares, but nothing on the paint that I can see.
Ford Bronco I need mud flaps, whats everyone using? 20230428_153337
2DR22Bronco
Chad
Seattle area
04Cobra, 95Cobra, 17Explorer, 89Bronco!!, 22Bronco
I bought the weather tech ones. When I bought them last year they were kind of the only ones I had found (and were in stock) that were able to be used with the sasquatch package.
Easy install, price wasn't bad either.
Axle Roads
Northern California (Gold Country)
2022 Bronco Badlands 2 Door, 2017 Nissan Frontier
I have RokBlokz XL, but should have went with XLL. The first dirt road after installing the XL’s they threw a rock and chipped/scratched my door that was about an inch long. I ended up making some 2” extensions (the same length as the XLL’s). They’ve blocked all rocks since. They look good and can be removed in a couple minutes without tools.
Ford Bronco I need mud flaps, whats everyone using? 7C707525-0D99-4834-9A69-3703CC62EF8B
Ford Bronco I need mud flaps, whats everyone using? A40C924D-22B3-4360-80ED-3A01B994F459
