Installing overhead aux switches after sales?
NewBroncoOwner
Did you end up giving this a shot? Been quietly watching this thread as I have a Big Bend and am in the same situation...
I am also curious to see if the base gets the shaft and the next trim level has it.
Advertisement
NewBroncoOwner
Went fishing in my A pillar for to see if I could find a plug or unterminated wires for upfitter switches. I did not have any luck. But I do have the unterminated wires at the specified locations on the vehicle for upfitter connections. I hope to see if others may have the plug and play option. As for me I will be hiding switches on the bottom of my steering column with 3m tape.
swooshdave
Portland, Oregon
Mustang
Vehicle Showcase
So were the wires behind the glove box there? Or at any of the endpoints? It could be that the engine bay harness is universal but the not the harness going to the back.
NewBroncoOwner
did not have great vantage point for pictures of the other wires, but yes glove box wire and rear wires are there as well as the grill wire.
PonyHunter
Detroit
Honda
So it sounds like it could be possible to order the Aux switches separate and run wiring to connect everything but it would be a lot of work? Sorry trying to understand what’s been posted.
Unfortunately my dealer forgot to add the switches to my order so I am trying to determine a solution.
NewBroncoOwner
Yes it will be a lot of work. Finding the correct wires, somewhere within the loom and then terminating them with the AUX pigtail, correctly, then buying the switches and the correct trim piece is well over $400. Time to complete it correctly could take well more than that in labor. Its up to you if that's worth it.
This Switch Block may be my best bet, could be yours too.
Tech Tim
Tim
Wet Side of WA
Jeep JKU
Here's a shot our Base non-Squatch that doesn't have the Aux. Switches but it does have wires in the engine bay.
NewBroncoOwner
I think they all have the engine bay and key location unterminated wires. It’s the plug and play capability in the cab that it lacking on non equipped aux packages
LowerSlowerDelaware
Lee
Subaru Outback, Chevy S10 Ram 3500
Has anybody done a stare and compare of a Base with the Overhead Aux Switches? Trace the wires to/from the fuse panel?
NewBroncoOwner
Got that 6 Gang switch kit from amazon. Real easy to mount in the cab, I utilized the Ford Bronco plate screws to mount the supplied mounting bracket under the plate. Seems like much of this truck is accessory ready! Lights will go on soon, they are on back order.
NewBroncoOwner
@NewBroncoOwner where did you mount the fuse block?
Right behind the Bronco Fuse box on the driver side of engine bay. There is some structure pieces to place some self tapping screws through the mounting tabs on the Auxbeam fuse box.
flip
Phil
IN
Fords
I think the connector going up is on the passenger side. C206
Connector Viewer - 150
C100AC100BC101C105C106C107C108C109C110C111C112C113C114C119C121C122C123C124C127C134C135C136C137C138C140C149C150C152C155C160C162C163C167C168AC168BC168CC171C175BC175EC177C181C182C183C184C192C197AC197BC200C201C203C205C206C207C209C210C212C216AC216BC217C218AC218BC218DC218EC218GC220AC220BC221C222C226AC226BC228AC228BC229C229AC229BC229CC233C236C240AC240BC240CC240DC248C256C258AC258BC259AC259BC266C278C285C286C289C296C297C300C301C302C305C310AC310BC318AC318CC319C322C322AC322BC322CC326C328BC328CC331C332C334C335C337C339C350C356C360C362C363C364C365C367C381C383C390C391C392C393C394C402AC402BC404C405C406C410C411C413C414C415C416C420C421C424C425C426C429C431C432C435C436C440C445C446C447C450C475C476C505C525C540C567C573C605C606C608C634C644C726C750C828C850C906C907C908C911C930AC930BC930CC930DC963C1016C1019C1021C1026C1033C1035AC1035BC1035CC1041C1047C1052C1062C1068C1073C1074C1077C1087C1100AC1100BC1100CC1100GC1100JC1101C1102C1104AC1104BC1104CC1107C1111C1112C1120C1137C1139C1140C1147C1148C1149C1151C1153C1160C1222C1271C1292C1293C1294AC1294BC1295AC1295BC1322C1323C1331C1365C1366C1367C1369C1370C1400C1401C1415C1416C1427C1428C1429C1430C1431C1445C1446C1450C1463AC1463BC1465C1466C1469C1513C1551BC1551EC1551TC1561C1562C1563C1564C1565C1566C1570C1582C1584C1615C1616C1617AC1617BC1617CC1617DC1617EC1617FC1617GC1621C1625C1627C1631C1632C1642C1643C1647C1648C1649C1655C1663C1674C1682C1689C1690C1702C1741C1748C1751C1766C1767C1792C1795C1836C1837C1840C1841C1842C1843C1844C1845C1846C1847C1848C1854C1895C1896C1901C1902C1903C1904C1905C1906C1915C1991C1992C1993C1994C1995C1996C2010C2010AC2010BC2010CC2039C2040C2091C2092C2122C2195C2235C2253C2254AC2254BC2280AC2280BC2280CC2280DC2280EC2280FC2280GC2280HC2354C2355C2356C2357C2363C2364C2370C2371C2383AC2383BC2383CC2383DC2383EC2383FC2383GC2385AC2385BC2385CC2405C2406AC2406BC2407AC2407BC2420C2421C2431AC2431CCC2431CDC2431CEC2436C2437C2438C2439C2490C2491C2494AC2494BC2494CC2515AC2515BC2515CC2515DC2564C2565C2608C2809C3006C3007C3051C3059C3075C3106C3159C3187C3189C3200C3201C3209C3210C3211C3212C3215C3216C3220C3240C3243C3245C3247C3318C3319C3323C3336C3336AC3336BC3336CC3338AC3338BC3388C3501C3502AC3502BC3522C3558C3559C3697C3698C3734C3825C4029C4046C4049C4099C4213C4223C4226AC4226BC4287C4320C4321C4330C4331C4336C4357C4359C4360C4369C4370C4397AC4397BC4397CC4452AC4452BC4452CC4478C4479C4544C4545C4546C4547C9018C9019C9026C9035C9064C9066C9224C9440AC9440BC9531​
Inline:DescriptionColorHarnessBase Part #Service Pigtail
C206INLINE14401 14335See Below
MALE
Harness
14401
FEMALE
Harness
14335
Check for Terminal Part Numbers
PinCircuitGaugeQualifier
1**
2CBP02 (GN)20
3CAC12 (GY-OG)14
4CMT18 (VT-OG)22
5RMT10 (VT-GN)22
6VMF05 (GY-BU)22
7VMF04 (BN-BU)22
8**
9CLN09 (YE-GN)22
10**
11**
12CMT10 (BU-BN)22
13VLN04 (VT-GY)22
14GD216 (BK-VT)20
15VDB25 (GN-OG)22
16VDB26 (GY-BU)22
17**
18**
19**
20**
1**
2CBP02 (GN)20
3CAC12 (GY-OG)14
4CMT18 (VT-OG)22
5RMT10 (VT-GN)22
6VMF05 (GY-BU)22
7VMF04 (BN-BU)22
8CBBD9 (BN-WH)22
9CLN09 (YE-GN)22
10DMM13 (BK)22
11**
12CMT10 (BU-BN)22
13VLN04 (VT-GY)22
14GD216 (BK-VT)20
14GD216 (BK-VT)22
15VDB25 (GN-OG)22
16VDB26 (GY-BU)22
17**
18**
19RMM13 (BU)22
20VMM13 (YE-GN)22
You can buy the upper harness for one with aux.
Advertisement
MRT
Advertisement
