Don't feel too left out. I have a 2024, built first week of April and delivered one week ago and it doesn't have those screen/options either.Must be for newer models. Not available on my '21 BL
Something seems amiss here.
I have a 4-door and that won't work for me. All my doors are locked unless I use the unlock button on the fob. If I grab a door handle to unlock, only the door I'm grabbing will unlock. The rest remain locked. When I have a passenger I open the driver's door, then push the unlock button on the inside of the door to let them in. Maybe my settings are different than yours?If you have a 4-door you can, just try the rear door. I get out, shut my door, hit the button on the handle and hear it lock, then I try the rear door to make sure
I verify mine by gripping the sides of the driver's door handle. I don't wrap my hand around it. That keeps the door from unlocking. The sensor is on the inside of the door handle. Grab the door handle anywhere else and it won't unlock.With the Bronco, I don't like that you can't verify if the doors are locked when you press the button because if you grab the handle it unlocks. I find myself having to listen to hear if the locks engage.
You have a setting wrong... you can change it to unlock all doors if you open the drivers or passenger door.I have a 4-door and that won't work for me. All my doors are locked unless I use the unlock button on the fob. If I grab a door handle to unlock, only the door I'm grabbing will unlock. The rest remain locked. When I have a passenger I open the driver's door, then push the unlock button on the inside of the door to let them in. Maybe my settings are different than yours?
Actually not. I'm happy the way it is.You have a setting wrong... you can change it to unlock all doors if you open the drivers or passenger door.
Me too. '24 Heritage picked up on 4/27 and I don't have that option on my Lock settings screen either.Don't feel too left out. I have a 2024, built first week of April and delivered one week ago and it doesn't have those screen/options either.
According to page 92 of the 2023 owner's manual you can test if the doors are locked. Just immediately pull on the handle after touching the lock sensor. It works on my Bronco. I just discovered this today. Before today I was trying to grip the handle without unlocking.With the Bronco, I don't like that you can't verify if the doors are locked when you press the button because if you grab the handle it unlocks. I find myself having to listen to hear if the locks engage.
