RedHotFuzz
2022 Bronco Black Diamond 4D
We don’t use regular Velcro. This is a hook and loop product from 3M. It has a heat rating up to 240 degrees. It uses an acrylic adhesive rated the strongest in the industry. It’s also the most expensive part of the shade. We have used it for years and this is even an improved version of what we have been using.
If you follow the installation instructions it will perform to it’s specifications. If you do not it will fail.
Hey Mike, does this magical material happen to come in white? That would make it less visually obtrusive on my white roll bars.
JTopsUSA
JTopsUSA
www.broncosunshades.com
Ram 1500 diesel,
Well it’s not magical but we have talked it over with our 3M rep.
Now you don’t actually ever see it unless the sun shade has been removed. In that case the top would be on and it would not be visible.
We will see what 3M has available.
RedHotFuzz
In my case I think there would be times I’d choose to remove the shade (as well as the top) for the full open-air experience, in which case white Velcro would be a nice option.
JTopsUSA
JTopsUSA
Ram 1500 diesel,
Understood.
I’ll discuss it with the production manager. It will have to be a selectable option.
Charlie
Charlie
Virginia Beach
2006 F250 Super Duty
So I was curious as to whether the field of stars would be available positioned over the driverside. I submitted the question to Support. I was pleasantly surprised to hear from Mike himself. Here is Mike's response. Thank you for replying instead of ignoring the question like other vendors have done.
The debate on the field had gone on for the 8 years we have been making our tops.
Even our competition has the field over the passenger side. I had a discussion with them and a few others at a show and we all agree it’s all in the point of view. It will never satisfy everyone.
We can do it as a custom design for you if you like. But we will continue it as a standard product with the field over the passenger side.
Thanks for your interest
Mike Matras
Owner
JTopsUSA
JTopsUSA
JTopsUSA
Ram 1500 diesel,
Mike Matras
Owner
JTopsUSA
Thank you for your understanding. I believe if we changed it we would get comments from the other 50%. I was thinking we could offer a choice. A user selectable option when ordering? That way everyone would be able to select their preference.
What do you think?
Skidog
Sandy
Encinitas
Bronco "21"Badlands 4dr 2.7,"23"2Dr Man,Tesla, Bmw
is there a discount for your shades on these fourms? Thank you!
JTopsUSA
JTopsUSA
Ram 1500 diesel,
Absolutely! Use cod G625 for $25.00 off. Thank you for your interest and if we can help in any way please let us know.
DropHunter
Rudy
Fl Panhandle
1995 Bronco, 2021 Bronco Black Diamond
Good question!
We are working on the install video but the best Velcro start point is an inch before the hook. We send extra if you need it.
The most IMPORTANT part! Clean the surface, apply the Velcro and rub the bubbles out. Then let it cure for 24 hours.
When installing the top put the front strip right up to the rubber windshield gasket. The corners should tuck slightly under. Stretch the front sides on a bit and then snug from the back where it goes over the roll cage. Then work the sides until it’s smooth and tight.
You can watch the 4 door video on the website. It is virtually the same.
Thanks for becoming a customer and if I can help just let me know.
Ford Bronco JTopsUSA Introduces the Bronco Bimini Sun Shade! 224B4B7C-2725-41E5-8DD0-464EAC36A518
I put my top on first, hooked the front hooks placed the top out using the magnets to hold it in place. Snugged it up with the back loops.
This let me know exactly where to put the Velcro.
Skidog
Sandy
Encinitas
Thank you. On your site now. Will order tonight! Thank you for your speedy delivery of samples. It very much helped!
JTopsUSA
JTopsUSA
Ram 1500 diesel,
Don’t live near the beach?
Bring it with you…
This has to be one of the coolest custom tops we have ever done!
Gina Q a graphic designer had us do this for her!
If you need some ideas to design a custom top she is available to help!
Bradley Thornton
Bradley
Hattiesburg MS
Bring it with you…
Ford Bronco JTopsUSA Introduces the Bronco Bimini Sun Shade! 8571FFE3-A9C2-4D24-B35F-C72ACFF8D8BB
I emailed you about this yesterday. Can I buy one also. I love this. If she says yes tell her thank you very much. That is just next level.
JTopsUSA
JTopsUSA
Ram 1500 diesel,
I will ask and send you her email. She ownes a design company and I’m sure she will help.
