Ambassador
Standing_Bear
Honda Civic, 2022 F150 Raptor
He Says Warthog would have advanced suspension at 17:32
s_white21
2021 F-150
Are Baja and Rock Crawl the only 2 modes where the front camera stays on? So an OBX squatch (for example) would only be able to have it on at a crawl?
Wyo
Wyoming
2023 Bronco Sas Badlands, 1968 Bronco, 2018 Expy
Is it summer yet!
beto3005
Albert
Houston
Kia Soul
Seeing the sway bar disconnect in action is making me rethink the Wildtrak. People say you don’t need it, but It seems like a feature that can prevent plenty of unfortunate situations for an off-road newbie lol
BroncoBoi
BroncoBoi
Austin
Royal Oak, MI
2016 Ford Focus ST
Coming from a basesquatch order, I would have to spend significantly more for a badlands, but if I had a comparable build price-wise, I would def be reconsidering!
North7
North Texas
SUV
Really good video by Exodus 4x4, in the chassis walk around he explains the differences to the Wrangler. However, he says the Sway Bar Disconnect is just like the Rubicon. We need to educate him on the difference, if they are reading this thread? The Bronco Badlands Sway Bar Disconnect is hydraulic, unlike the Rubicon which is electric. The Badlands can be engaged on uneven ground, unlike the Rubicon.
There is a deep dive here:
BWI Bronco Stabilizer Bar Disconnect Technical Information
Felix808
SRV CA
Those tires are also larger than Sasquatch tires. They're a true 35" tire. Most 315's are closer to 34".
Not going to be much of a difference. The KM3's in that size are 34.5" Most 315's will run anywhere from 34.4 to 34.7". In fact a KM3 315 17 will run 34.4"
North7
North Texas
SUV
I wonder if the ride quality is going to be as good with the standard suspension included on the lower and unsquatched trims. Do the Bilstein dampers make that big of a difference? All the ride-along stuff is on Badlands suspension...I wonder if there's a reason for that.
Yes, the Bilstein dampers make a big difference, here is a deep dive.
BILSTEIN ESCV Bronco suspension / shocks explained - "End Stop Control Valve" Dampers (Bronco HOSS Suspension w/ Position Sensitive Dampers)
TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2023 GMC AT4 HDD
What’s the difference between sand and Baja mode?
Base Sasquatch guy wondering.
I figure just put it in sand mode and gas it.
DETT
Okay I have to admit, after the first KOH ride along video I started thinking I might want a BL over the OBX build I had.
But now after this video I'm ABSOLUTELY switching to a 2.7 BL.
Washington
1969 Bronco, 2002 Tacoma, 2015 Wrangler
I am sure the "just like" comment was simply regarding basic function, as in they both disconnect the two sides of the bar. They discussed the technical and operational differences at length later in the video after using it on the ride.
Happytown
Ryan
Zachary, Louisiana
2013 F150 Eco SCREW 4WD
If it’s like their other vehicles it will be a noticeable improvement. But the Ford performance parts suspension upgrade should get it there for less than a trim switch.
Can this upgrade be included in initial order, factory installed? I saw the thread with the accessories list etc, never really took a deep dive on what was available or when.
Sampsonrustic
Sampson
SoCal
F150 4x4
It will be dealer installed I believe. Or buy kit and diy
kermitfrog
gareth
uk
drive
I guess
Its probably something people might want to think about depending on what your plan is on use .The bilstein dampers with End stop valve is probably a better suspension set up for high speed desert raceing smoother over humps and ridges and mayebe a advantage in rock crawling .Standard suspension with out the End stop valve will probably make the ride rougher and harsher if useing for the above situations but for anything else the ride quilty should be good.
