TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2023 GMC AT4 HDD
I like the 1up racks. I have a Kuat NV rack and have replaced many parts on it over the past 6 years. Kuat makes them very reparable and have fast parts shipping. However, I prefer the design of the 1up. It's less deep and doesn't stick out as far from the car when it's not being used. And the racks are spaced closer together so they are closer to the car when in use. Also it's basically 100% aluminum and there's very little to corrode. Both 1up and Kuat make good products. But my next rack (when I can no longer repair the Kuat) will be a 1up. FYI I love my Kuat roof ski rack.
I had a Thule T2 original rack for 10 years before my current set up. I sold it for almost what I paid for it after 10 years. It worked great for me but I do like my new 1up set up better.
Crash98
Viet
Bremerton, WA
2017 Ford F-150
Does the Kuat pivot work with other brand of racks? Or is there something special that makes it only work with Kuat racks? I think I want the pivot to use with a ski/snowboard carrier.
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
Works with any 2" hitch device.
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
I added my Curt hitch, Kuat Pivot v2 and old NSR4 rack this past week, works great! Still throwing the bike under the hardtop for security if I need to be at the office before ...
Honestly having the same detents for the Bronco swing out and the Pivot is pretty rad, allows you to just swing it open.
Ford Bronco Kuat Piston Pro X Bike Rack + Pivot Pro 2.0 Hitch Extension PXL_20220923_200702293
Ford Bronco Kuat Piston Pro X Bike Rack + Pivot Pro 2.0 Hitch Extension PXL_20220923_210957495.MP
Ford Bronco Kuat Piston Pro X Bike Rack + Pivot Pro 2.0 Hitch Extension PXL_20220923_211149934.MP
FellowM3
Northern NJ
Current: 22' Braptor, 2020 BMW M340
How much space between the bottom of the tire, and the pivot v2 do you have?
I have a pivot v2 and just got the raptor and worrying about if the pivot will fit between the tire.
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
With oem Sasquatch tires have a bit to spare!
FellowM3
Northern NJ
Ford Bronco Kuat Piston Pro X Bike Rack + Pivot Pro 2.0 Hitch Extension PXL_20220930_151030213
any chance you can measure that?
I believe if the tire is in the same position, i would need an extra 1.2"
Sas tire technically is 34.6"
Braptor tire is 37"
Difference = 2.4" / 2 = 1.2"
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
Braptor tire is 37"
Sure but it will be a bit!
Overlander22
jt
NorCal
2wd/2.7
I have confirmed with both Kuat and 1Up that neither the Pivot v2 nor the RakAttach 2.0 swing arms are RV rated nor off-road rated on 4wd vehicles. Given this, any thoughts about which system would be strongest for RV and off-road use?
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
Yeah, off road use...def won't have a swing out due to the extra material and leverage. You definitely have to make some compromises. I recall only one rack that I've ever seen is off-road rated and it was a yellow vertical rack from some company in the northwest about a decade ago... Let me see if I can track it down...
I couldn't find that original company, but this seems to be the most popular current solution https://www.isi-carriers.com/products.html
