- Mike
- Oct 8, 2020
- 2
- 233
- 650
- Grapevine, TX
- '67 Camaro
- Badlands
Does anyone know what all went into the lift that 4WP did for the SEMA build?
You won’t be able to lift the Bronco 4” (or more) unless you go with either a diff drop lift kit (Skyjacker, Rancho, Fabtech, etc) or a mid-travel kit, which is substantially more expensive. The diff drop is necessary to keep stock length CV axles and tie rod angles in check, but the downside of installing one of these kits is you will negate much of the ground clearance gain from the lift under the front axle. It’s basically stock height ground clearance up front after the lift excluding the ground clearance gain from tire size. You’ll improve your approach/break over/departure angles at the expense of a higher center of gravity. Good for mallcrawlers, bad for off-road. If you’re only going to street your Bronco or take it on the beach/gravel roads or mild trails, this lift is fine. Plan on $1.5-3K depending on lift/shock options.Let's get this thread going again. Rig is being built in two months. I see some placeholders on sites like Stage3 and FabTech, but nobody seems to have anything ready.
Badlands non-Squatch with 7M. I wanna go up 4" and 37s.
I was hoping not to have drive around on the stock stuff, but it doesn't look like any aftermarket stuff is going to be ready at the beginning. Anybody know anything otherwise?
