Yep, I got the rock rails for my bb to cover that weld and protect the rocker from gravel more than to slide over boulders.
No rails needed on thoseGoogle āImogene Passā or āWhite Rim Roadā videos ā¦ these are some trails I am looking forward to trying.
I am surprised you can speak so authoritatively without knowing the vehicle specs, the drivers skills, etc?No rails needed on those
Are those the factory rails?Yep, I got the rock rails for my bb to cover that weld and protect the rocker from gravel more than to slide over boulders.
Yes, purchased from flip at Ruxer.Are those the factory rails?
Well because I've been on them numerous times in numerous vehicles and in any Bronco you will not bounce the rockers on a rock. You may drag the fuel tank, axle or suspension component, but not a rocker. I am assuming the driver is even slightly competent.I am surprised you can speak so authoritatively without knowing the vehicle specs, the drivers skills, etc?
You have more confidence in me than I do!!Well because I've been on them numerous times in numerous vehicles and in any Bronco you will not bounce the rockers on a rock. You may drag the fuel tank, axle or suspension component, but not a rocker.
Any chance of water getting underneath them? That was my biggest worry with these.A little pricey, but WELL worth the money! I couldnāt believe how much better it made it look. Itās the look that it should have come from the factory. I highly recommend getting this. Best bang for the buck with the most positive visual impact mod Iāve made.
HNY! No not sold yet. 4drDid you sell these yet? 2dr or 4dr?
Ugh! Looking for 2Dr.HNY! No not sold yet. 4dr
I am curious about this too.How did you install the trail armor?
Do you need to remove the side step tube first before installing the trail armor?
I did the White Rim in my BL. If you drive off line you "might" find use of your rails but in all reality you won't touch them. Moab on the other hand....can confirm, they come in handyGoogle āImogene Passā or āWhite Rim Roadā videos ā¦ these are some trails I am looking forward to trying.
Better to have them and not need them ā¦ plus there is the ārocks in tires thingā though I wonder if they adequately cover the quarter panels from thrown rocks vs rocks underneath.I did the White Rim in my BL. If you drive off line you "might" find use of your rails but in all reality you won't touch them. Moab on the other hand....can confirm, they come in handy
They dont provide much cover if any for rocks flung by the tires, at least on the squatch tires. but i agree better to have than notBetter to have them and not need them ā¦ plus there is the ārocks in tires thingā though I wonder if they adequately cover the quarter panels from thrown rocks vs rocks underneath.
