SpiritAnimal
Illinois
2012 Camaro SS
Cross post from this reddit. Looks like a 2022 big bend where someone attempted to do a burnout right off the dealer lot. Absolutely annihilated their clutch with only 10 miles on the drivetrain. 😱😱😱😱
The comments indicate that the flywheel was blackened, so that means things got really hot! My guess is that it was a clutch dump at high rpm, but it isn't a heavy enough clutch to hang on. He probably saw smoke and thought he was doing a burn-out, but was dumb enough not to be able to tell the difference between burning clutch smell and burning rubber smell. 😂
These Broncos aren't race cars. I would be surprised if it is possible to do a burn-out at all in one.
Ford Bronco Madman burnt his Bronco's clutch with 10 miles on odometer - right off dealer lot 🤯 2021-2022 Ford Bronco clutch burnt fried3
Ford Bronco Madman burnt his Bronco's clutch with 10 miles on odometer - right off dealer lot 🤯 2021-2022 Ford Bronco clutch burnt fried2
Ford Bronco Madman burnt his Bronco's clutch with 10 miles on odometer - right off dealer lot 🤯 2021-2022 Ford Bronco clutch burnt fried1
SZairborne
Shayne
Minnesota
2018 Dodge charger GT AWD
Wow, all you can say is wow!
bytheway
Brice
Louisville, KY
Not sure I could do that if I were trying.
RunNGunArk
Brad
Fort Smith, AR
2022 Badlands Sasquatch
odds are this is some "influencer" trying to build following and relevance online? "SIGH"
greenmachine343
md
bronco
I dont even know if i can spin my tires on my car because of the infant small 1st gear
I think it happened once while pulling out , that or it was just a turn squeal
XirallicBolts
Xira
Wisconsin, USA
2016 Flex EcoBoost, 2022 Silverado LT
If that guy got his while some day one and two res holders still live without, there is no justice in this world.
>Four door Big Bend soft top
What a shocker. Probably a dumbass influencer grabbing whatever was sitting on the dealer lot
GaryB2220
Gary
Wellsboro PA
How do you fk up this bad? Did he have the accelerator to the floor and kept the clutch halfway engaged? Or did he dump it under full load and it gave out? Need some details.
SpiritAnimal
Illinois
2012 Camaro SS
The comments in the reddit thread indicate that the flywheel was blackened, so that means things got really hot! My guess is that it was a clutch dump at high rpm, but it isn't a heavy enough clutch to hang on. He probably saw smoke and thought he was doing a burn-out, but was dumb enough not to be able to tell the difference between burning clutch smell and burning rubber smell. 😂
Paul Gagnon
Paul
Sherwood Park, Alberta, eh?
I doubt that there is an issue with the clutch holding power. Most people don't know how to do a burnout with a manual transmission anymore.
Both engines have more than enough power to get the wheels spinning without a lot of effort. A 2.7L Sasquatch can easily break the tires loose from a standing start just by mashing the gas. .
Moto26
Tucson AZ
Maybe he forgot to turn off the traction control?
