Manual Take Rate - 25% per Ford Authority
MaverickMan
Shane
25% may be high enough to open up the options, like mid or high package, sas, and the 2.7 or dare I say warthog. They just needed to make the case for line setups and bellhousing development.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I would have picked up the Black Diamond if the manual could be speced with the MID package. I ended up getting the default Outer Banks since it comes with the mid package.
After I realized that mid wasnā€™t possible with the manual and I had less than 12 hours to decide if I wanted to put down a deposit I went through each and every item you get for the additional $1500 (+$3000 for AT) and there wasnā€™t much I was upset about missing out on. Whatā€™s necessary for you in the MID package that you canā€™t live without? Serious question.
Iā€™m excited to see what 22 and 23 have to offer.
siddious33
Charlotte, NC
2011 Jeep Grand Cherokee; 2016 Dodge Challenger Hellcat
Has there ever been any real input from Ford on the 2.7 and manual?
I believe I read the 2.3 and 2.7 were different bellhousing patterns which would complicate that slightly
Pretty sure the current manual transmission isn't rated for enough torque for the 2.7 engine, if I remember correctly. Or it was close enough to be borderline.
BroncoRaptor
Al
Ashville, NC
MBZ Sprinter Van 4x4
For me, not much. But this a shared family car, so it was these: heated seats, intelligent door access, backup assist, built in nav (don't allow smartphone usage inside the car - they go in the console while driving) and other safety features like pre-collision and lane keep assist. - We also like that you get the remote start with the auto - helps a lot in the California desert, esp with the soft top.
Amcap76
2018 F250, 2019 GT-350, 2004 Jeep LJ
Manual take rate would be even higher if Ford didn't gatekeep Mid + 7 Speed to Badlands trim only. I can't get mid with a manual BB or BD so auto it is.
We better hope they don't gatekeep ManSquatch to Badlands only as well.
Ford Bronco Manual Take Rate - 25% per Ford Authority F7906256-8EF2-4792-BBDD-AA5D4F566F62
Rahkmalla
NJ
15 K900
If ford wants more money from me they will allow 2.7 Base mansquatch. My car as ordered is 31380. The ONLY things that are increasing my selected options are manual 2.7, and mansquatch. Badlands mansquatch only? Screw you I'll selfsquatch. 2.7 auto only? I'll stick with the 2.3.
nick112288
Nick
Lawrenceburg, IN
95 Ram 2500
If I remember correct it is scalable up to just shy of 600 ft/lbs. No idea what it's rated to as currently built
MannyG20
Ted
F-150
Agreed. I 99ā€™d for the Base ManSquatch. If they restrict it to the Badlands trim only then I will get a plain manual base.
TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2023 GMC AT4 HDD
This % will drop over time.
Liberty
Bill
Central Illinois
Chevy Silverado, Black Diamond Bronco
The MT take rate is way off. Hereā€™s the order mix (USOB)in April just before production began. This was provided by Zach @ Granger
Ford Bronco Manual Take Rate - 25% per Ford Authority 1630583294092
The other quoted take rates (SAS,etc) were pretty close
GToddC5
Todd
South Jersey
www.bronco6g.com
Yes I'm worried about this myself, I'm interested in a Base ManSquatch but I could see Ford restricting it to Badlands. I also don't understand why you can't get a manual in a Base 4 door.
Shit, you can't even spec a 2Dr. MT BD with Mid package! It's crazy.
I fully expect limitations to ManSquatch, so will likely stick with Badlands and SelfSquatch.
We'll see . . .
noliveaxle
john
Riverside, Calif
2015 jku rubicon
this is number is high because the Big Bend, Black Diamond and Badlands default specs are with a manual - so, if you put in a reservation and never updated your order with the dealer, you are getting your favorite trim with a manual and no options - you can see all these show up on dealer lots now and not get picked up by the original person that reserved it.
Iā€™ve seen only manuals available for sale here in so cal. 4 of 4. But the 30k mark ups surely donā€™t help sell either.
rugbysecondrow
Pauly P
north carolina
1964 C-10 stepside
One complaint I see on the internet is that everyone says they want a manual, but no one actually buys them. Looks like in the Bronco's case a healthy percentage of people are putting their money where their mouth is! Great to see, and also per the article the SAS take rate is over 50% which leads me to think that once ManSquatch is available the manual percent will be even higher!
https://fordauthority.com/2021/09/2021-ford-bronco-7-speed-manual-take-rate-is-about-25-percent/
People will end up buying what Ford decides is most efficient and profitable to build/sell. this is what will be stocked on the lots, which will vary from the various take rates from orders.
I suspect you will see many stock 4dr, auto, non-sas.
indio22
Chicagoland, USA
I'm a base 2-door manual guy. But in a moment of weakness, I tried to price a base 4-door manual. Found out the 4-door base is not offered in manual.
Unfortunately manual has one hand tied behind it's back in terms of restrictions.
