Where are you getting the 75% Bronco ratio?Did some math - Assumptions (assuming post 1 in this thread is actually correct):
May 3rd - 350 units per shift, 2 shifts per day, 75% were Broncos, 5.25 days per week (factor in non-work Saturdays, holiday, conservative "fudge" factor) - June 7th starts retail builds - added 12.5 units per week (per shift) ramping to 600 units per shift on "Full Tag Relief Production" Sept 20th date (again, conservative).....came up with 125,212 Broncos assuming MY21 was till December 20th (subtract 4725 per week if over shot the December date/week switch to MY22) - of course the big unknown is parts/chips/fires/pandemics......
Am I missing something or my math messed up? We should see a lot more than 60K Broncos shouldn't we??
Link to math
Taking liberties (guessing) based on part of the first post in this thread:Where are you getting the 75% Bronco ratio?
A Ford Engineer who said he was involved in the planning of the Bronco/Ranger production at MAP once posted that MAP was designed to run 72 units an hour with 2 10 hour shifts and Saturdays as needed. The initial ratio of Broncos to Rangers was 43 Broncos and 29 Rangers, but MAP would be capable of running any mix. Mix would always be subject to market demand and part availability.Did some math - Assumptions (assuming post 1 in this thread is actually correct):
Link to math
So that is approx 60% Bronco, 40% Ranger........with all the same math, swapping in 60% for 75% = 100170 Broncos and also worth noting, I stayed with the 350 ramp up to 600 per shift......which is conservative as compared to 72 units/hr.....which would be 720 per shift (10 hr shift).A Ford Engineer who said he was involved in the planning of the Bronco/Ranger production at MAP once posted that MAP was designed to run 72 units an hour with 2 10 hour shifts and Saturdays as needed. The initial ratio of Broncos to Rangers was 43 Broncos and 29 Rangers, but MAP would be capable of running any mix. Mix would always be subject to market demand and part availability.
The only variable you don't have is when they will actually switch over to MY22. I've seen everywhere from Nov-Dec.Did some math - Assumptions (assuming post 1 in this thread is actually correct):
Link to math
I like it, but it's just way too optimistic for me.So that is approx 60% Bronco, 40% Ranger........with all the same math, swapping in 60% for 75% = 100170 Broncos and also worth noting, I stayed with the 350 ramp up to 600 per shift......which is conservative as compared to 72 units/hr.....which would be 720 per shift (10 hr shift).
My take is that Ford is intentionally underestimating (around 50K) to temper expectations due to parts availability......definite unknowns there.......but what this math does say is that, MAP and Ford are very capable of cranking out 100K of MY21 Broncos - which is likely great news for those not commodity constrained.........and if they really do focus on Bronco building and have their suppliers work more on Bronco parts than Ranger parts (for example), we could (and should) see a far greater number than 50K MY21 Broncos.......
A few months ago we all thought we had to wait until May to get our estimated build dates......not the case......looks to me like Ford is doing everything (within reason for a business) to make this move faster than initially thought possible. I'm going to be positive and have faith in Ford.......besides, won't get my Bronco any faster being unhappy about it
Just want to be defeatist, don't 'ya. Like my first divorce lawyer kept telling me: "Keep hope alive brother". Little known fact, I was at that rodeo that day soothing a broken heart by riden' broncs. It wasn't very long till I was dating Bo Derek.I like it, but it's just way too optimistic for me.
