Minimum lift for 37’s?
Jeffz95
Kiowa, CO
Nissan NV 4x4 van, 78 911, 08 Jeep Rubicon
Looking for best set up to run 37” tires on stock wheels with minimum lift. 2021 Wildtrak/SAS. Want it to be functional off road and keep hwy comfort too. Pics and input please.
Raptor.Tremor.Bronco
Miami, FL
2021 Bronco Wildtrak, 2014 Raptor, 2020 Tremor
If you want it to be functional offroad you need to get aftermarket fenders. Plain and simple. ADV sasquatch width will be the way to go.
BAUS67
redneck
Central PA
I would agree with the above post and add 37x11.50 tires will also fit better with stock wheels than the 12.50 or 13.50. 😁
My plan to a tee when Ford decides to build my 2DR V-6 and ADV finally releases the 2DR 5 inchers. ;)
Rockdawg84
Sam
Tucson, AZ
98 4RUNNER, 96 F350 CC 4x4
no lift is about as minimum as you can get. Lift does not create clearance. that being said lift does other things like improving brakeover, approach and departure angles.
here is mine. 37x12.5r17 mickey Thompson Baja Boss MT's which are about as true 37's as you can get. I had rubbing on the front crashbar mount so I used the Big tire clearance kit and now am good to go.
Ford Bronco Minimum lift for 37’s? 976CB4F0-8C98-4EBB-8030-BA42EF17C59E
Ford Bronco Minimum lift for 37’s? 4EAA564C-8F68-4A38-9413-AC4BE0303061
Ford Bronco Minimum lift for 37’s? C4BD2199-08C2-41AE-B96A-D70685FC003A
Ford Bronco Minimum lift for 37’s? 23242EC3-5F25-4E05-8DE2-102356FC866D
Ford Bronco Minimum lift for 37’s? 4C87CF00-D84B-47A7-817D-310E3C5E4393
Ford Bronco Minimum lift for 37’s? A975BAA4-29E9-405C-A6AC-5DA10AEC604D
Ford Bronco Minimum lift for 37’s? 2FC46375-0819-41BA-8855-4BBF2AFFB495
Ford Bronco Minimum lift for 37’s? D8EDFA9D-1AE4-4E3A-8009-CB5A3B8D4B60
Jeffz95
Jeffz95
Kiowa, CO
You’re asking for a unicorn bud
Not really! my 08 4dr. Jeep Rubicon has a 4" lift and running 37's for years and very roadable and does rock buggy stuff when I want. There is the right combo out there, thats what Ia am looking for. Thx
RainbowStix
A Big Island
Toyota Tacoma
And the JL I had 3yr ago ran 40s with no problem after the upgrades were said and done. It’s a completely different platform.
even the funhaver running the latest preproduction parts rubs on 37s
only way to have it functional off road (meaning no rubbing on compression) and on is to almost completely gut the front suspension and wheel well.
youll need about 4.75” of BS, the JKS max clearance kit, high-caster heim UCAs, maybe cut the rock rails if you have it, delete the flares, and cut about 3/4” off the fender. Alternatively, you could figure out a way to shorten the compression stroke of whatever shocks you’re running in the front and skip the last step. Keep in mind with changing the UCAs, you’re gonna make it less functional on the road unless you’re a fan of feeling every single tiny bump on the road and harder steering.
Or go with a belletech/RC drop bracket lift.
I’ve never seen a bronco wheel with 37s zero rubbing yet.
Jeffz95
Jeffz95
Kiowa, CO
have you tested on trails for clearance during flex and such ? looks good.
we’ll! I stand corrected. Guess I’ll keep the 35’s and do the serious wheelin in the J/k 😀 my wife wants to keep the Bronco a mall cruiser. Still want to set up for some fun stuff. Thanks for the info. BTW Fun Hager’s set up seems pretty nice.
mcinfantry
Lee
Louisiana
Badlands 2 door
Im curious if these will work with no lift
texasmark04
San Antonio, TX
2017 Jeep Wrangler Unlimited Rubicon
I have the same tires just put on, the Mickey Thompsons Baja Boss, but I went with the A/T's for less road noise as I don't do a lot of "hard off-roading". I did do a 2" Zone Lift to adjust the stance. The only time I get slight rubbing is full lock reverse out of my driveway. I thought with the Sasquatch the crash bars were deleted, so I don't think I'm rubbing on those since mine is Sasquatch. I looked at seems to have plenty of clearance, but haven't really done a full test to view.
Ford Bronco Minimum lift for 37’s? 2022OBXAfterLift
SasquatchMansquatch
4 door basquatch
You'll need to remove the parts the interfere, that's more important than a lift for running big tires.
Broncotrax
NORCO
69 Bronco, '17 Superduity, '22 Badsquatch, CR 250R
This is a good subject to follow for sure. I have a 2 door Badlands Sasquatch. I will cut the braces out as well plus add the 1.5" body lift from Bronc Buster. This way I have Fords factory suspension and maintain geometry but I should clear 37's. If no one can verify, I will as soon as I can.
Rockdawg84
Sam
Tucson, AZ
Looks awesome!! I removed the mount the crash-bars go into. If you’ve heard it rub a couple of times just look around the paint rubs off pretty quick and you will see.
texasmark04
San Antonio, TX
Ah got it, will check for that then, thanks for feedback! Is removing the mount for crash-bars pretty simple? I think I saw in a thread you can use a reciprocating saw to remove them?
