mpg numbers before December?
XCR440
Nathan
Union, Iowa
21 Badlands traded for 22 Badlands, to 23 Wildtrak, to 24 Wildtrak
I don't think you'll get MPG numbers until production starts. I've never seen an official announcement on Bronco Sport yet (but the numbers are showing up on the window stickers of early orders).
That said, I don't think the stickers will matter for real world if you're comparing gears and tires. EPA will just rate an average setup and put it on all of them. Look at F-150, I pulled up a regular cab 4x4 5.0L with 3.31 gears and smallest 17" tires it's sticker was 15 city 21 highway. Compared it to a Crew cab 4x4 with 3.73's and 20" wheels, the rating is the same 15 and 21.
Mopar2Bronco2021
Houston
2018 Dodge Charger RT 5.7L
F-150 weighs about 4,600 pounds on average and it isn't the most aeroynamic with a bed on the back and the 2.7 gets in the 20s. I got 17 around town in my 3.5 EB.
Yea there’s some pretty high F150 numbers that owners have posted on YouTube from their 2.7L. One video in particular showed a 10 speed with the 2.7L get 24.8 mpg @ 75-80mph in a relatively flat region of the country. I assume the owner was on stock tires though.
@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
Keep in mind that the speedometer is off as well so you are traveling more miles than what it says.....I put 35s on my rubi. I think it dropped from 20 to 18 ish....so about 10 percent. Between 33s and 35s you are doing about 6 percent more miles.....so a 4 percent decrease ish... Its not anywhere near that bad.
Disclaimer....JL with the 2.0 and 8 speed.
from the factory should adjust your speedometer to your tire size. if not you can also do that aftermarket
Broncomputer
Los Angeles
GTI
Goodness gracious folks, this horse has been beat to death so much that now it's just a pile of meat and bone chunks that have been sitting in the hot sun so long that even the opossums won't come near it! The MPG difference between 33s and 35s will be in the ballpark of 1-2 MPGs, tops 5, but probably not 25-30 percent. Running 35s on my 3.5 Ecoboost F150 (with a 93 tune), I get around 17-18.5 on the highway and that's in the Ozarks where we have plenty of hills. On the flat ground, I can get a little over 20 MPG. Right now my average for over 5k miles is around 18.1 MPG and I have 173k miles on the dang thing. If you can't keep your foot out of it, your MPG will be trash. If you drive like you have some sense, you will do just fine lol.
Well, 25% of 20MPGs is 5MPG...so:ROFLMAO:
Regardless, I'm hoping for at least 20MPGs mixed driving. Anything more than that would be great...my old S2000 and WRX both got between 18mpg-19mpg, but tech has improved since then so I think it will be a wash.
Stitches1974
SW Florida
2019 Dodge Challenger Scat Pack
Yes, factory will, but they were talking about a rubicon with 35's that you can't get from the factory, save a very few limited edition models, but those are not made anymore IIRC.
tshaw2009
Tony
Lebanon, MO
2011 F150 Lariat, 2018 Ford Edge Titanium
You're going to be lucky to get that without the Sasquatch package. And the 5 MPG was tops so therefore would be an extreme. This vehicle could weigh about 300-500 more pounds than a Screw F150 with the 2.7L w/ 10 spd auto depending whether you choose 4x2 or 4x4. Then look at the 4-door Bronco. It will be even heavier. If you're looking for a vehicle that is going to get good MPG, the Bronco is probably not going to be the vehicle for you brother. Sorry to break that to you. Hopefully Ford surprises us but don't hold your breath.
Ford Bronco mpg numbers before December? 1603819542054
Ford Bronco mpg numbers before December? 1603819828254
da_jokker
Jeep Wrangler JKUR
I think alot will boil down to driving. If I drive at "legal" freeway speeds like 55-65 my car gets into the 40's ... if I drive "my" freeway speeds like 75 my car gets low to mid 30's.
So with the gear ratio calc from that other post, the V6 seems to be turning basically the same RPM at 70 mph if you get Sasquatch as if you don't... fingers crossed.
moresmoke
ND
Wrangler Chief
If you have to ask about mileage, you should be shopping a different vehicle.
I can guarantee the Bronco will do better than my F350 with a 6.8!
Silver-Bolt
Bill
Eureka, MT
Are you running 4.7 gears and 35's?
AZHUND
2020 RAM 1500 5.7L 4x4, 2018 Wrangler S 3.6L
I am willing to bet $5 that the EPA numbers are ~1 better than an equivalent Wrangler since they are benchmarking it in so many other ways. It also wouldn't surprise me if they don't get EPA numbers for the Sasquatch and just stick the lying numbers on the sticker since I think that is a loophole you can use if rest of vehicle is the same (RAM does it across their 1500's despite huge differences with the ones with AT tires and offroad/higher springs than the street tire low-riding ones...).
Also real-world is way different than EPA, especially for vehicles like this. You drive in windy conditions and lose 20% right there, replace the C rated tires with E rated and lose 10% there, put it in 4WD-H and lose 10% there, etc. Not a Prius...
Stitches1974
SW Florida
The Bronco will most likely get better city mileage than my 6.4 does. 15 MPG normal driving or 13 MPG in sport mode.
Wyo
Wyoming
2023 Bronco Sas Badlands, 1968 Bronco, 2018 Expy
The Raptor is 15/18 with 35s (3.5L) and much heavier. Is it unreasonable to think a 2dr Bronco with 35s will get a little better than that. So 16/19 or 17/20. Lower gears though on the Bronco 4.7 vs 4.1. Thoughts?
