My MIC 2.0 started the popping noise at 1,300 miles
Herbie
Alex
Cleveland OH
2022 Badlands
HoosierDaddy
Where can you buy the little condoms? I only know where to buy extra extra extra large size. 😝
Maybe dental supply?
Lol, dentists/hygienists used to use little finger tip rubbers.
Jabberwock
Craig
Georgia
2011 Toyota Tundra
I came to the same conclusion you did after examining the pins and realized it was exactly what you were talking about. Some of the pins are missing that little rubber condom and sure enough, those are the pins squeaking. I have your post bookmarked now to spread the good word.
I didn’t know there is supposed to be a rubber cap over the plastic pin. I have some rubber caps of different sizes that are designed to fit over plastic tubing of various sizes so I may try one and see if that works. The only problem is they are fairly thin and would likely wear through.
BRBlue
Houston
Toyota Tundra
Mine just started at 10k miles. Silicon spray on the rubber alignment pin did the trick for now.
HoosierDaddy
A tiny amount of lube seems to do the trick!
A few months back, I used vaseline (cleanest "lube" I could find in the garage) on the pins. I've had them off and on a number of times now ... still dead silent.
Techun
Pa
BD, 2.7, MIC, 4dr
Tiny strip of electrical tape
okbob
North of the Red
71' u15, 66' u14, 66' u14
BRBlue
Houston
Toyota Tundra
This is the official lubricant recommended by Ford in their Technical Service Bulletin to fix this. It’s a silicone grease called Krytox…
Krytox by Chemours GPL 205 Grease, Pure PFPE/PTFE, 0.5 oz Tube (D10170248) https://www.amazon.com/dp/B00MWLDALQ/ref=cm_sw_r_cp_api_i_A0MK4YR45X7MB7N7QD2S
Fuzion2Bronco
Asher
Base Sasquatch
This solution seems to take care of the popping sound:
