V1Rotate
Bryan
Brevard, NC
2022 Wildtrak
@HavocOffroad Installed my steel bender rear bumper last night and looks good/super happy with it but ran into one issue you guys might want to consider. It’s set up to use the factory backup sensors/stock harness but the issue is that the two center sensor holes are about 6-8” further apart than they are on the stock bumper. The factory harness won’t allow both center sensors to reach their respective holes without splicing in/extending the wiring on one of those two middle sensors. The outer 2 are great, just the center spacing is too wide for the stock harness
SGXIX
The highly anticipated Steel Bender front & rear bumpers are available now!
Inspired by the canyon lands of Moab, the Steel Bender Front Bumper from HAVOC Offroad is built to be as tough as the trail itself. Crafted from a muscular 1/8-inch steel plate, the Steel Bender takes a no-nonsense approach to bumper design. No bells, no whistles, all business. The Steel Bender features a low profile stinger with concealed hardware and massive 1-inch thick dual-drilled recovery hooks accept 3/4 and 7/8-inch D-shackles and provide a convenient snatch point for a kinetic rope. At the corners, integrated hi-lift jack recesses stand at the ready to give you a solid lifting point for trail repairs. Plus the Steel Bender Front Bumper is compatible with all the Bronco’s factory equipment like proximity sensors and front camera, not to mention OE and aftermarket flares, so your Bronco can tackle the rough stuff in style.
https://havocoffroad.com/p/havoc-offroad-steel-bender-front-bumper/
https://havocoffroad.com/p/havoc-offroad-steel-bender-rear-bumper/
What size fog lights does the front bumper fit? Will diode ss3 fog lights fit?
BeerRunner
LUKE
Blythewood, SC
2023 Bronco
It will fit the OEM ones I know. The bracket sit a bit back from the opening so I don’t think any size too large
BeerRunner
LUKE
Blythewood, SC
2023 Bronco
SGXIX
BeerRunner
LUKE
Blythewood, SC
2023 Bronco
OE fogs 3.5
BeerRunner
LUKE
Blythewood, SC
2023 Bronco
Hole opening seems to be at least 4.25". I should manage to fit the diode ss3 there. Thanks!
also you install from behind - so size is pretty much irrelevant
SGXIX
Do you think the diode dynamic ss3 would blend well with overall look of headlights and bumper + rount fog lights holes? You've already installed the bumper and have a better overall idea.
BeerRunner
LUKE
Blythewood, SC
2023 Bronco
What are the dimensions? maybe cut that out on cardboard and do the same for round bumper hole and see what you think.
Or you could dry fit and return them it you don’t like the look but if money wasn’t burning a hole in my pocket, I’d save it for something more functional and buy someone’s OE fogs for a fraction on the cost
Personally with signature round headlights, I’d want everything round. My cyber truck on the other hand when it comes, will have no round edges where it can be helped.
SGXIX
That's how I was feeling about it. Will see if I can find someone selling the OEM lights.
SGXIX
SGXIX
Ford Bronco New HAVOC Offroad Bumpers - NOW SHIPPING IMG_0756
Do the Base model tow hooks need to be cut in order to install this bumper? Or there is enough room to leave those as is?
