redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Individual switches on each of the lights would have been a nice touch.
da_jokker
Jeep Wrangler JKUR
Here's another idea... At the top of the roll bar in the cargo area, there is a accessory ready mounting point (guessing it's for the sound bar?)
When you guys release this, seems like you should be able to add one more light to the rear cargo area that takes advantage of that mount. This way you're getting the four cabin area lights, plus a rear cargo light (of course I would expect the price to go up a bit but not get crazy)
Adding the ability to swap lenses for clear, amber, red, blue, etc And you'll have a highly demanded product for sure
I only ask for a group buy discount for my awesome idea 🤣
Olekz
Bronco 2022
Excellent suggestion seems like it would be easy to accommodate… Thoughts?
da_jokker
Jeep Wrangler JKUR
I got the idea because the other day I was in my cargo area and I had one of those harbor freight lights with a hook that I hung up there in that accessory spot.
Lit up the back area perfectly. I'm half tempted just to hang that thing up there and call it a day, but it uses batteries and it would be just all around slicker if I could flip a toggle switch and light up the entire Bronco.
https://www.harborfreight.com/light...t-portable-led-worklightflashlight-63878.html
IAG Performance
IAG Performance
JJ
Westminster, MD
www.iagperformance.com
Excellent feedback! We are working on a cargo light option so that is already in the works. The ability to change the color of the light seems to be popular, so we will have to discuss internally whether that is something we can make work and how we would go about implementing that if we decide to move forward with it.
kbBronco
Kyle
Carrollton, TX
2021 Ford Bronco, 2019 Honda Rebel 300
My body is ready for these lights, and a plus one for the ability to alter the color between white, amber, and red would be an absolute game changer for me with my sleeping baby And camping trips! On the waitlist and looking forward to seeing this come to life.
Summit981
Paul
Maryland
Porsche Cayman, MINI GP2, MINI Countryman
Put me down for a set of these lights for my 2022 Badlands. I also will cast a vote for adding the capability to alternate between white or red lens. Sometimes you need to go tactical and having the red lens lighting really helps you find what you need in the truck at night without destroying you night vision in camp.
BCFDLtE13
Wayne
Manchester, MD
2015 Mustang GT Performance Pack
I'm in for a set...don't really need/want the color change. A switch on each light to operate independently would be good. Either way...send it.
Garemlin
Delaware
I’m guessing you could have these hooked up to come on when the doors open or switched with one of the upfitter switches.
Also what’s that pull cord you used to flip up the top???
da_jokker
Jeep Wrangler JKUR
I think in a previous post they say that pull thing is something that may be coming down the road.
As for the power options, these specifically did a video just to answer all these questions. It's very informative so You might want to take a look
Garemlin
Delaware
I did watch the video. Didn’t see anything about powering to the switches. Guess it shouldn’t be that hard. I haven’t messed with any of the switches yet so we’ll see.
Snowdogyyz
22 Ford Bronco Badlands
From the very first post-
The included plug and play wiring harness makes installation easy, with just one wire to connect under the dash. Once installed, the lights work seamlessly with your OEM dome lights and even dim when turning off- just like stock!
They’ve also said you can run them to an aux switch.
IAG Performance
IAG Performance
JJ
Westminster, MD
The included harness will allow you to have these come on when any of the doors are opened. There is also a separate pigtail that you can run to your factory upfitter or aftermarket aux switches.
