Dirty Bronco
Brad
Charleston
2021 Ford Bronco - 4 Door Badlands
The ordering page is live. I was able to order a set around 8:58 AM EST.
da_jokker
Jeep Wrangler JKUR
Freakin' awesome! Thanks for all that. OK, I'm an accountant! So as to wiring these lights from IAG, if I want to run a wire so that I can hit a switch and turn them on whether the vehicle is on or off....sounds like I can't do that to an AUX switch? I'd have to hook to a wire behind glove box? And if so, then how does it turn on/off? Thx.
Not sure if this will help or not, but as mentioned none of the auxiliary switches are powered once you shut the Bronco off. In addition, most of the power in the Bronco is on a CAN BUS system which simply means you can't just tap into it for power.
So IAG gives you 2 methods of wiring these up which you can do either one separately, or both depending on what you wanted to do.
Method one powers the lights on when your door opens. This obviously works with the Bronco off but there is no way to control if they come on (eg they are not linked to the overhead dome light buttons). So say you're out at night and you open your door and you do NOT want the entire parking lot seeing your business...you are SOL.
The second method allows you to wire it up to an auxiliary switch. So you can control when they come on and off as long as the Bronco is powered on.
Now based on a few of your post, it seems like you may not be clear as to how the auxiliary switches work, and how the leads throughout the Bronco work.
All six switches (some very by amperage) are powered but their leads all are disconnected at the right rear of the firewall.
Right next to that spot at the firewall, are connection points that lead to various areas of the Bronco. Those are dead wires. So say you want to use auxiliary 3 to power the wire that leads to behind the glove box... You simply go to the firewall, find the wire for auxiliary 3, find the wire that is run to behind the glove box, and connect the two.
Sonin the case of these lights, you run their aux switch lead to either the one behind the glove box, are the one above the sun visor that's meant for a light bar. Then under the hood by the firewall, you decide what auxiliary switch (use one of the smaller amp ones) and connect that to the dead wire lead to make it live and done.
Dirty Bronco
Brad
Charleston
As of 9:08 AM EST the 4 door hardtop kit is out of stock
Eroc88
Ohio
Jeep
Finally was able placed an order. Crazy within minutes after ordering, they are already out of stock for the 4 door hardtop.
JeebusCripes
Mn
‘94 M998, ‘89 Wrangler
damn... I'm sorry to hear that :( either supply is low or these are super popular.
Hey Ford, do you think this may be a design flaw if all these people are scooping up this solution?
Dirty Bronco
Brad
Charleston
WTF! Hilarious. I was on a 9:00, by the time I put my credit card info in they were out. I got Van Halen tickets easier in 1984.
If trying to get a PS5 taught me anything it was to do the following..
1. Create account on the website
2. Enter payment information and shipping address ahead of time and save it to your account.
3. Be on the page hitting F5 even a few minutes before the scheduled release time. (In this instance the page was actually up and running a few minutes before 9 AM)
porkchop express
Ken
South Lyon, Michigan
2020 camaro ss 1le, 2017 focus st, 2020 ram
Thanks. I'm a slow typist.
'23 Bronco | '16 Mustang
Started ordering at 9:00am (apparently I'm a fool for not trying before the actual drop time) and it was out of stock (4dr) by the time I typed my credit card...
I guess they weren't joking with "limited quantity," I wonder how many were available?
Ksjrb03
Tx
F250
The large Bronco groups were watching and waiting for these too, they are very popular.
IAG Performance
IAG Performance
JJ
Westminster, MD
www.iagperformance.com
We are releasing HUNDREDS of kits at a time. These were just incredibly anticipated and popular. We are building as fast as we can!
Hearing "hundreds" sounds a bit like Tobias "We're building dozens!" as I'm sure demand is in the thousands! I'm sure you have a count of the "Notify me when in stock" records, I'd be curious how many thousands it really is.
Glad they're so popular and this a successful product for your business. Looking forward to the next round!
Any estimated dates for the next drop?
IAG Performance
IAG Performance
JJ
Westminster, MD
The next drop will be Friday 2/3.
