Jpursuit
J
Houston
2008 f250 king ranch 4wd, 2021 Bronco
For those that weren't able to get a set on the first batch. Looks like there is an error with the count down clock on their site. There are 2 of them. 1 shows 1 hour away and another one shows 2 hours away. I believe the next batch is released in 1 hour - 9AM EST.
sold out again before I could order
Bt_ostate
Oklahoma/Colorado
2021 Ranger Tremor 2021 Bronco 4-Door FE
When will you have them for hardtops? All you have in stock is for soft tops only??
IAG Performance
IAG Performance
JJ
Westminster, MD
www.iagperformance.com
The hard top kits sold out in 8 minutes this morning. Building more as I type this and will have another drop next Friday.
JFelty
Minnesota
Mustang Mach E
Got my 4dr soft top kit this morning. Didn't sit by my PC waiting because I had an early morning meeting. Looks like there are still some out there.
Thank you @IAG Performance
IAG Performance
IAG Performance
JJ
Westminster, MD
Shipping kills this for me in Canada...
99 dollers for lights.
65 dollers to ship it!!!!!!!
Inventory is tight at the moment just based on the sheer volume of people looking to get these. Once we get over that hump, reach out to us directly through phone or email and we will see if we can figure out a cheaper shipping method for you.
AK007
Washington DC
Awaiting my Bronco
I cant remember the last time I entered my cc number that fast! lol
Firefight911
Phil
Simpsonville, South Carolina
2022 Ford Bronco 4-door Wildtrak, Eruption Green
Mine has arrived!!! Clear that calendar and, "let there be light."
DRC
Cedarpines Park, CA
22 Bronco
I was finally able to place the light kit order for the 4 door hardtop yesterday at 7:36PM. Received a tracking number at 8:32AM this morning. Yeah
FRM
Russ
IDAHO
1978 Bronco, 22 Bronco Base , 19 Ranger
Just ordered mine!!!
hozer
Calgary
Suburban
Didn't expect a concert ticket like sellout :( looks like I'm waiting till next Friday.
Dwadeuru10
Derrick
Herriman, UT
Hyundai Sonata, Santa Fe
I didn't realize this many Broncos were actually produced with Hardtops, haha. Glad I'm just stuck with the soft top...But still ordering before they run out.
Headsong
Not sure if this will help or not, but as mentioned none of the auxiliary switches are powered once you shut the Bronco off. In addition, most of the power in the Bronco is on a CAN BUS system which simply means you can't just tap into it for power.
So IAG gives you 2 methods of wiring these up which you can do either one separately, or both depending on what you wanted to do.
Method one powers the lights on when your door opens. This obviously works with the Bronco off but there is no way to control if they come on (eg they are not linked to the overhead dome light buttons). So say you're out at night and you open your door and you do NOT want the entire parking lot seeing your business...you are SOL.
The second method allows you to wire it up to an auxiliary switch. So you can control when they come on and off as long as the Bronco is powered on.
Now based on a few of your post, it seems like you may not be clear as to how the auxiliary switches work, and how the leads throughout the Bronco work.
All six switches (some very by amperage) are powered but their leads all are disconnected at the right rear of the firewall.
Right next to that spot at the firewall, are connection points that lead to various areas of the Bronco. Those are dead wires. So say you want to use auxiliary 3 to power the wire that leads to behind the glove box... You simply go to the firewall, find the wire for auxiliary 3, find the wire that is run to behind the glove box, and connect the two.
Sonin the case of these lights, you run their aux switch lead to either the one behind the glove box, are the one above the sun visor that's meant for a light bar. Then under the hood by the firewall, you decide what auxiliary switch (use one of the smaller amp ones) and connect that to the dead wire lead to make it live and done.
Thx for that! Will read 8 times until I understand it all....I would like the option to NOT have them come on all the time. What if she bumps the door handle while...oh, never mind.
