Paint issues
@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
My paint has numerous defects. went to PPF straight from dealer and the overall quality of the BIW is bad and very inconsistent. Not much I can do about it now, most defects are covered by trim but it gives me lack of confidence when I see a large area on the door panel without paint but the other side looks perfect
Or the numerous edges that have defects under the clear coat.
Silver-Bolt
Eureka, MT
Now that I go back and look at the pics again, something isn't adding up. I commented above but going to do so again here.
There are light, superficial scratches all over the place, in every pic. Did you wipe it with an old microfiber, dry, dirty hands while it was dusty, or something there? Or did it look like that from the Dealer?
Someone, somewhere scratched the shit out of it and it needs buffing, at minimum. Even taking all of the defects out of the mix.
Have you ever seen the the wash/detail area at a dealership? If the don't have an old brush type car wash they have a buck with an old mit or rag. The water might get changed monthly. Soap? Naw, too expensive. My bet is the scratches are from the lot jockey that "detailed" it prior to deliver. The actual paint defects and debris is another story.
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
Yeah took delivery two days ago. I have a dent in the left quarter, dent in hood, and defective passenger side curtain airbag plastic trim piece. Dealer says they’ll be fixed so we’ll see…
BC overlanding
IN/KY area
LMAO you guy complain about taking to long to get your Bronco. Ford rushes to get them out now you complain about fit an finish.
you know the old saying
1. Good
2. Fast
3. cheap
pick 2
Any Bronco defiantly isn't CHEAP
not saying this don't suck but what did you all expect
HeliPilot
Kenny
CT
2022 2.7L SAS
I would suspect some type of damage occurred after production and probably during shipment.Those pics look like there was damage, repaired, and wet sanded. That explains the light scratches, the small divot, and what looks like a fisheye that was sanded through in the clearcoat.
calgecko
Sacramento, CA
www.instagram.com
2021 Chevy ZR2 Bison V6
Mustangs had issue with corrosion on the hoods (also aluminum) as well
