- Kyle
- Apr 13, 2021
- 41
- 111
- 443
- Houston, Texas
- GMC yukon denali
- Base
Is it possible to fit 35 inch tires on a base two door Bronco?
you can get the samsquanch package with35s on the baseIs it possible to fit 35 inch tires on a base two door Bronco?
It is. May take a lot of modifications that may well be far more expensive than going with Squatch to begin with...Is it possible to fit 35 inch tires on a base two door Bronco?
This so reminds me of the Wrangler forum, seems that everyone that buys a wrangler (new to off road) wants to know what lift they need to fit 35’s (or 37’s or 40’s etc) of course it’s more than just a couple coil spacers.It is. May take a lot of modifications that may well be far more expensive than going with Squatch to begin with...
Not only a lift, but you’ll need at least a +30mm offset wheel for the tires to clear the upper control arms.The answer is likely no without modifications. They will likely rub without a lift. Once you get it lifted, you are likely to have weak power unless you do a regear of the axles. If you then off-road, the front axle will be subject to breaking with the larger tires.
If you ever want 35s, get Sasquatch. It’s ultimately going to be cheaper than a DIY version.
Sure....but you will never be able to take it offroad ever without worrying your axles are strong enough and the tires will probably rub everytime you turn.Is it possible to fit 35 inch tires on a base two door Bronco?
NoThis place is like 7-11...open 24hrs...do you guys ever sleep?
NOT a Base7:09 Mark sounds like 35s with no mod to me.
