Premium fuel!
DHH
Here
2019 Ranger
On my Ranger (2.3) I can't notice the difference in power between the two grades. I only put premium in when I plan to tow long distances.
There are some on Ranger5g that say they can notice a difference, but a lot say they can't.
Based on the posted dyno graph, the 2.7 shows a larger increase in power than the 2.3, so maybe with that motor you'll notice the difference. But even on 87, the 2.3 is impressive and the 2.7 is going to be a beast!
VelocityBronco
E
Bronco Badlands, F-150 FX4, Explorer Platinum
Very small gains to be made using Premium fuel. F-150 with 3.5L Ecoboost in this testing showed 5-7% gain in gas mileage, but only 2-4% gain in HP. Do those gains justify the $.60 cent per gallon cost? Thats up to you...
Now if you are running a specific aftermarket tune, that changes everything, this testing is for stock vehicles.
Dick_Castlesmurff
Dick
Washington D.C., District of Columbia
Forester
Where do you get ethanol free premium? None in Laredo.
Ethanol free gas is easier to find at rural/small town stations.
Ethanol is hell on small engines, and old farm equipment. Pretty much anything with a carburetor that might sit for a while between uses. After the gas evaporates the ethanol lingers around and gets gummy.
Anyway, for that reason you'll see it in places you might not expect.
Southern Girl
1974 Bronco/2024 Wildtrak
And EB's. I try to use ethanol free gas with mine when I can get to those stations.
BroncoBell
Stephen
San Antonio
We have much better BBQ in Corpus than Rudy's. Rudys is more like the fast food of BBQ here. But I'm not judging...it's where you live on what choices you have.
I kind of get it but not really. Fast food BBQ is more like Dickies and Bill Miller's. First time I ever heard Rudy's called a fast food... not mad, just processing the thought. Even though it's a chain, which isn't the same, I say they're on par with Blanco BBQ (San Antonio), Coopers (New Braunfels), or Buzzies (Kerrville).
Where's your favorite BBQ place? I'm a huge fan of Joe's up in Kansas City, Kansas.
WuNgUn
Ontario Canada
2 door Squatched
On the Ford Bronco website, i saw today that the Bronco boasted best in class power for the 2.3 and 2.7 liter engines with an asterisk that denoted premium fuel required. Im pretty sure i saw that regular fuel was recommended but what power loss will we see if we dont use premium?
All EB Ford engines are like this. They adapt to the fuel used. If you wanna use 89 octane dishwater, fine... It'll be ( unnoticeable) less power and slightly less mileage... But if you wanna play $ to miles travelled, it's likely a wash compared to premium.
Milamdj
Nashville, TN
Nissan Versa
Thank you for the info.
Stitches1974
SW Florida
2019 Dodge Challenger Scat Pack
Costco premium is my plan - if the extra 20 cents has any noticeable difference on power or MPGs (it does not on my JLU 3.6L - but does on my 5.7L HEMI and wife's crossover) I will have no hesitation paying it. Anything to up the 'smiles per miles' is worth it.
That's because your 3.6 is an 87 only motor and the hemi is a 89 or 91 ( depending on stick or auto ) Premium is wasted on the Jeep, unless it's tuned.
AZHUND
2020 RAM 1500 5.7L 4x4, 2018 Wrangler S 3.6L
Thanks for stating the obvious... was just saying to use higher octane fuel when it makes a difference.
Stitches1974
SW Florida
Excuse me for trying to explain why there was no improvement. Don't make statements that would give you such replies then.
BossMann
Louisville
2009 Honda Pilot
87 is perfectly fine for low compression engines. turbos tend to be high compression so premium may provide benefits. Lucky for us the computers can detect early ignition if present and adjust accordingly.
Studawg
SC
02 Excursion, 96 Land Cruiser, 18 Land Cruiser
I will be running Top Tier (name brand), Premium (91 or higher octane), ethanol-free (E0, PURE GASOLINE) in my Bronco, no matter which engine I end up choosing, as much as feasibly possible. I am in a location where premium, ethanol free is readily available.
Im not looking to pinch pennies, Im looking for peak performance and reliability.
JT58Bronc
JT
Fl
2022 Bronco, 1987 Chevy Squarebody 4 X 4
I ran 89 octane initially in my past 2017 Fiesta ST. I switched to 93 and could feel a significant difference, increase in power. Although it ran trouble free on either octane. In my 2018 Mustang GT I ran 87 octane and it did not run well. It pinged and it had excessive piston slap. It sounded horrible and the dealer said it was "normal" ticking covered by the TSB. It got so bad I got rid of the car. I hope that either engine in the Bronco will run fine on 87. I don't like paying .60-1.00 more a gallon if I don't have to.
nbennett14
Nathan
Illinois
13 Fusion, 14 Fusion, 07 Expedition, 14 Grand Cherokee SRT
Serious question, what is the advantage or the point of getting Ethanol free? Only reason I ask is b/c I am from a big farming community and a lot of people push the ethonal.
