Question about Aux light switches in Outer Banks model:
khoward9
keith
dearborn, mi
bronco
I received my Outer Banks but did not order the Aux Light switch options on mine. Does this mean that my vehichole has NONE of the wiring to all the aux locations? I was hoping to find out that wiring does exist (example the roof light bar mount location) - and I just need to setup/install a switch to control. If anyone has worked through this issue, I'd appreciate the feedback.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
khoward9
keith
dearborn, mi
bronco
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Thank you so much... I was concerned about this and had NOT started looking yet for the wires.
Well hang on there. I'm in the same boat as you. Outer Banks with no upfitters.
So that thread does state that YES the upfitter wires ARE under the hood. I've confirmed this also. The problem is, the OP on that thread could not find the upfitter wires INSIDE the cab, especially up by the sunglass holder. I verified this also, there was no harness up there (but I only gave it a QUICK look by prying down a small panel, i've yet to continue my search).
I don't see anywhere where the OP DID find the harness bundle inside... soo we're still not 100% sure WHERE those upfitters go. Look, they SHOULD go somewhere right. Why else would they be under the hood and not ran inside the cabin, right? Unless ford only has them go to the fuse panel and then from there, they didn't run the wire bundle inside? Possibly. I'd sure hope not.
At the end of the day you COULD run your own harness up there. But it may not tie into the trucks relay systems is all.
