Quick-Release Mud Flaps
datasci
datasci
Nissan Murano
I want to get some front mud flaps with a quick-release feature for my Badlands Sasquatch.
The two that I know of with this feature are Rokblox and Gatorback. I have my Fordpass points, so that would knock the Gatorbacks down to roughly the same price as Rokblox.
So, two questions:
- Between Rokblox and Gatorback, any opinions on which quick-release works better/easier?
- Any other brands to consider?
Jr87mustang
Josh
Northern Cali
I have the Rokblox and they look and work great. Having the two thumbscrews make quick work of removing them. They also work with just about any step/slider.
The Gatorbacks don't come all the way off and they look like a truckers mudflap on a semi. Also, depending on your setup if your using stock rock rails you have to get the version with a hole in them, if you switch your rails out later you will have to buy a new set of flaps.
helifino16
Ron
Mount Sinai, NY (Long Island)
Reach out to @Biltwild - he is working on a Solution for the Stock Rock Rails (if you have them) that are easily installed, so I'm guessing they're easily taken off as well. I watched him put these on a FE in about 10 mins. Might give you another option and if you use thumbscrews, you won't need tools.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I have the Gatorbaks and love them. Just need to slide out a small piece at the end and the bottom portion of the mud flap slides out. Takes seconds to do. I also think they look much better than other options on the market.
Biltwild
New York
2014 Nissan Titan Pro-4x , 2021 Ford Bronco 4Dr BD
So, two questions:
If you have the factory rock rails mine will slide right in and uses 1 bolt and a plug. Should have the product live in the coming weeks. We are just finishing up our production molds.
Send me a DM for more info if interested.
darinhouston
Darin
U.S.
Bronco, Jeep Wrangler, Bronco Sport, Pallisade
Anything new on this?
