Raptor Bronco Suspension or other
Losy
Long Beach, CA
Gen 1 Raptor, GL63, S7
There is quite a bit of information on YouTube about the Bronco Raptor suspension. I believe it will be using fox 3.5’s which won’t fit under your OBX. But you would get similar performance to your F150 with the fox 2.5 shocks or King 2.5. Suggest you also add upper control arms when you upgrade the shocks.
freezey00
freezey00
Anthony
NJ
Bronco OBX
Would it fit on another version of the truck?
looking to get a good upgrade but also fit 37’s.
BR0NCO
Randy
Mass
Jeep Audi
Completely different mount setups. Not bolt on
Losy
Long Beach, CA
I would go with the King 2.5 set up and RPG upper control arms. With a little trimming of the wheel well liner, you can fit 37’s. It will lift the Bronco between 2-3 inches.
freezey00
freezey00
Anthony
NJ
Bronco OBX
I don’t mind spending the extra to get to the 4” lift and upgrading shocks / springs / etc. what would be in that class?
Losy
Long Beach, CA
You may be misunderstanding. the Fox 2.5 or 3.0 Hoss, 3.5 Fox, or others shock brands is not measuring lift, but the diameter of the shock. Larger diameter stays cooler and can add performance for serious off road use.
wes
1984 bronco ii x5
The closest lift Iv seen so far to a raptor build would be the icon stage 8 lift kit. With the electronic adjusting valving it’s the closest Iv seen to a raptor suspension. Hide your wallet though your looking at around 10k not installed and installed probably anywhere from 12-15k
freezey00
freezey00
Anthony
NJ
Bronco OBX
Ahh ok yeah that I didn’t understand. Thanks.
freezey00
freezey00
Anthony
NJ
Bronco OBX
yeah I saw some of these today.
wes
1984 bronco ii x5
What are your goals with your bronco? Lift it or crawl or race? Streets? Why do you need the biggest baddest suspension?
Richtor
Sonoma County
20 Tremor 7.3, 21 Badlands Sasquatch Stick(order)
I want the Bronco DR suspension and travel! Drooling!
freezey00
freezey00
Anthony
NJ
Bronco OBX
My bronco goals are mostly just a nice clean looking lift with a good ride quality. Most of my time will be spent on the streets. I don't think i need the biggest and baddest - just trying to overall find something that fits well for the outerbanks.
Rockdawg84
Sam
Tucson, AZ
98 4RUNNER, 96 F350 CC 4x4
if you want that then you should look for a set of Badlands or Sasquatch coilovers. I have a badlands Sasquatch and am running 37's with no lift what so ever. Rides great and flexes good. I am going to be adding the JKS front body mount and there will be no rubbing at all.
https://www.bronco6g.com/forum/threads/jks-manufacturing-max-tire-clearance-steering-sleeve.40091/
Ford Bronco Raptor Bronco Suspension or other 399F3D30-6EB6-4259-8F08-BD45D1C11410
