Rear Too Stiff
chartzilla
Morrison, CO
2000 Land Rover Disco 2, '79 Corvette, '17 Elantra
I have a 4 door Badlands and also feel like the ride quality is pretty harsh. It's mostly the rear springs, it makes you keenly aware of every bump on the highway. Reminds me of a Tacoma I rented a couple years ago.
I'm confused because I know all the reviews say the ride quality is great compared to a Jeep, but I find that sort of hard to believe. I wouldn't expect the ride quality to be as smooth as a sedan, but I have a 20 year old Land Rover with solid front and rear axles that rides smoother than this.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
I've had similar thoughts and almost posted them on the "unpopular opinion" thread. I'm running 32 psi now and the front isn't too bad but the rear is still fairly harsh over small bumps. The easiest solution might be a giant subwoofer box with a couple 15's in the cargo area.
LeBronco
'19 Expedition Platinum
you bought the wrong model!! You are missing two doors. LOL
seriously this is the best riding off road vehicle i have ever ridden in!!!!! light years ahead of the wrangler!
chartzilla
Morrison, CO
I've never actually driven a Wrangler so maybe that's part of my problem. I've ridden in them several times and never recalled a particularly bumpy ride but maybe I just wasn't paying attention.
But like I said, I have a 2000 Land Rover Discovery 2 that rides significantly smoother than my brand new Bronco. It's body on frame with solid front and rear axles. Weighs about the same as the Bronco and has E load rated 32 inch all terrain tires. Which would all suggest a harsher ride than the Bronco... But it's oddly better than the Bronco. It does have upgraded 2" lift springs and Old Man Emu shocks so I suppose that could be giving it an edge?
I have noticed that people have only been complaining about harsh ride quality the past 3-4 months.. Is it possible Ford changed the rear spring rate for 2022?
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
They did add a rear sway bar on some models for 22 but I haven't seen a definitive list of which ones get it. On uneven bumps that would increase the effective spring rate.
kodiakisland
Arkansas
I'm happy with my rear end (no jokes), but I've replaced trailing arms and track bar to get rid of all those hard rubber bushings, so maybe that helps. I certainly wouldn't call it a harsh ride on or off road. That's also with a lighter than normal load, as top and doors and rear seat are gone.
I guess I'm also used to Blazers on lifted leaf springs and my Tacoma on lifted leaf spring.
chartzilla
Morrison, CO
Interesting, I'll have to check and see if mine has that.
chartzilla
Morrison, CO
Edit: nevermind this is the track bar...
Ford Bronco Rear Too Stiff 20220608_101605
broadicustomworks
Hanging Rock, North Carolina
It's this bar behind the rear diff right? Looks like I do have one. Also looks pretty simple to remove, just two bolts. Maybe I'll try taking it off at some point and see what difference it makes...
No, that's your track bar.
chartzilla
Morrison, CO
Duh.. shows how much I know about suspension components.
Looked up a proper picture of the rear sway bar and confirmed I do not have one
Ford Bronco Rear Too Stiff 20220608_111632
broadicustomworks
It's all good, buddy. None of us know until we do about anything.
Before I had my first Jeep and did a suspension upgrade I wasn't sure what the technical names were for some of it either.
Out of some old bad habit I STILL call the rear trailing arms "Rear Control Arms".
Brnco2.7
Dexter Michigan
1976 Bronco
I have 5000 miles on mine and I was just thinking today that it feels like it drives better over bumps.I think it takes a few thousand miles to break in the suspension. I live 3 miles down a dirt road and really notice the bumps.
Ground_zero298
Scs michigan
They take about 1500 miles for the suspension to soften up, at least mine did. Psi should be adjusted to you’re liking. I feel anything over 40 is uncalled for on something like this. I’m running 32-34 psi. Lowering the psi helped from the get go, then one day the suspension just decided to smooth out. Now she rides good on the highway. Thought it was horrible when I first drove it home.
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
I felt the same to a point. Only have 850 miles on mine. There is a section of road by my hose I hit everyday on the way home from work, that is roughed up by construction traffic In my Jeep JL with a lift, it was a harsh ride over the bumps, I am feeling them a little more than I thought I would in my 4 door Sasquatch.
I took it off road for the first time over the weekend, and I think it is about compromise. I went down some rutted trails much faster in the Bronco then I would have in the JL. I think it may give up some on road plushness for off road Baja style driving. I really noticed on the wash boarded dirt road in and out of the Trail areas, if I went 5 to 10 miles an hour it felt like my teeth were going to fall out....but if I went up to 35-40 MPH it was a smooth ride.
From videos Ive seen of suspension travel, especially on trails with people going medium speeds, I think the down travel dampening is some of the issue, it looks to me like it has less rebound dampening than maybe it should. Meaning the suspension drops faster over voids after bumps than it should. Just my 2 cents.
