Red fluid leak. Transmission fluid?
Mlarv
TN
2023 Bronco/ 2022 F150/ 1968 Mustang
Did you start it and see if you had a wrench light? I don't think tranny fluid will freeze, and what ever that is looks frozen. Also feel and smell it to see if it fells oily and smells like tranny fluid.
SS Bronco
Shayne
Loomis CA
2021 Bronco , F600, F5, LJ20
Looks like you cracked your pan. It looks icy, probably a chunk hit your plastic pan. Replace parts are around $250 should be a stock item at your local dealership. Unless you added a skid plate , factory leaves the transmission pan exposed.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Yikes.
Kurt1
Kurt1
Kurt
St Paul
Jeep Grand Cherokee
Turned it on and no light comes on saying there’s a problem.
Kurt1
Kurt1
Kurt
St Paul
Jeep Grand Cherokee
Interesting. Thanks for the info.
It seems something happened as I was warming it up because it was leaking when I walked out and was not leaking when I left it there the night prior.
SVTLightning
Christian
Canada
Titan
Did you crawl under at all and take a look? Yes from the picture clearly some fluid has leaked out, but no way for anybody to tell exactly why from this picture.
BigHoof
PA
Ram 2500
No way I would start it without looking more closely at the issue. That much fluid ought to be easy to figure out where it came from.
Lifeliberty
Moonbeam👀
Columbus, OH
Probably look at your transfer case and transmission.
Your basic car fluid colors are clear, blue, green, red, gold/black
Brake
Washer
Antifreeze
Trans
Oil
Lifeliberty
Moonbeam👀
Columbus, OH
I didn't think transmission has a fluid level sensor
Mlarv
TN
Not for fluid level but fluid pressure. If there is that much fluid the pressure would be low and toss a wrench light.
RHeinz
Ric
Houston, TX
Fluid generally doesn’t run up hill. Looks like the low spot is under your car where the fluid is puddling. May have come from the vehicle that was parked next to you.
Try putting it in reverse and see if it will move.
Since you posted it this afternoon, the issue may already be resolved. I would not drive it any distance without crawling under it to check for issues.
If in doubt, have it towed to a repair shop.
Baja Bronco
2Sun AZ
22 Ford Bronco, 20 Ford Raptor
Ouch! If nothing else, that would be a better avatar pic for you. Let us know what happens.
1975U15
2019 F-350 SD, 1975 Bronco
Smart. May have been from car parked perpendicular.
OP Crawl under and should be obvious if yours was leaking the fluid.
