- Thread starter
- #1
Walked out to my car in the parking lot and found what I think is the transmission fluid leaking.
Anyone had this issue?
Turned it on and no light comes on saying there’s a problem.Did you start it and see if you had a wrench light? I don't think tranny fluid will freeze, and what ever that is looks frozen. Also feel and smell it to see if it fells oily and smells like tranny fluid.
Interesting. Thanks for the info.Looks like you cracked your pan. It looks icy, probably a chunk hit your plastic pan. Replace parts are around $250 should be a stock item at your local dealership. Unless you added a skid plate , factory leaves the transmission pan exposed.
I didn't think transmission has a fluid level sensorTurned it on and no light comes on saying there’s a problem.
Not for fluid level but fluid pressure. If there is that much fluid the pressure would be low and toss a wrench light.I didn't think transmission has a fluid level sensor
Smart. May have been from car parked perpendicular.Fluid generally doesn’t run up hill. Looks like the low spot is under your car where the fluid is puddling. May have come from the vehicle that was parked next to you.
Try putting it in reverse and see if it will move.
Since you posted it this afternoon, the issue may already be resolved. I would not drive it any distance without crawling under it to check for issues.
If in doubt, have it towed to a repair shop.
