***** RELEASED - PICTURES POSTED ******* Bronco Raptor billet aluminum front upper a-arm coming soon
BigMeatsBronco
Allan
2021 FE 2 door
Yes ours work with the factory stock wheels.
Are you talking about regular base bronco? those arms dont look like the Bronco Raptor arms. We make the billet arm for both but wanted to get you the correct info to answer your question.
I'm showing the factory Bronco SAS OEM upper ball joint has substantially more available angle than FabTecs 1" uniball....I see you use a BIGGER uniball, that fantastic because with the same sized bolt and hardware it SHOULD have a bit more angle available.
just asking you to show this. some joints like the delta pro and others offer up to 90° of movement.
I'm doing a 2dr Raptorization....meaning I will use Braptor front suspension on my 2dr FE. I plan to buy aftermarket UCAs and OEM LCAs so I'm following this thread.
GregFoutz
GregFoutz
Lux Sponsor (Level 2)
Greg
Mesa
www.foutzmotorsports.com
21 bronco, 21 ford Raptor
I dont have stuff here with me to compare but maybe this helps
all the way forward
Ford Bronco ***** RELEASED - PICTURES POSTED ******* Bronco Raptor billet aluminum front upper a-arm coming soon 1685827134975
all the way to the back
Ford Bronco ***** RELEASED - PICTURES POSTED ******* Bronco Raptor billet aluminum front upper a-arm coming soon 1685827193277
GregFoutz
GregFoutz
Greg
Mesa
Perhaps our new Bronco plus 3 wider kit would be a better option for you then trying to adapt the Bronco Raptor stuff to a regular Bronco. The frame mounts and geometry is way different.
our Bronco mid travel kit is 3" wider per side. with heavy duty fabricated lower arm, fabricated or billet upper arm. and you can add 3" bypass shock and bump stop. Works with the stock bilstein or aftermarket replacement coil over shocks. This kit is in testing now and ready to release for sale in the next couple of weeks. this is the first look.
Ford Bronco ***** RELEASED - PICTURES POSTED ******* Bronco Raptor billet aluminum front upper a-arm coming soon 1685828189643
Ford Bronco ***** RELEASED - PICTURES POSTED ******* Bronco Raptor billet aluminum front upper a-arm coming soon 1685828284863
BigMeatsBronco
Allan
2021 FE 2 door
perfect thanks for all the information.
