- Jason
- Dec 6, 2021
- 6
- 59
- 149
- Maple Valley
- 2021 Bronco 2dr Wildtrak
- Wildtrak
Not for the faint of heart! But worth the time and effort.
Thought I'd share my experience.
I love the ol' school Chrome OEM Bronco script emblem, but I didn't want a stick-on emblem for fear of it warping, or melting off on a super hot 100+ day. (During the summers, I spend a fair amount of time in the "desert" of eastern Washington, Lake Chelan, Moses Lake).
I purchased an original script emblem from BroncoGraveyard: FORD MOTOR # C6TZ-16098-A
Note: The removal of the front quarter panel was not as easy as advertised! It is NOT a quick process, and I don't recommend it unless you're ready to FULLY commit. (which happens as you as you start removing the grill)
Installation required removal of engine bay plastic front gutter-trim, front grille, lower grille facia, fender, rubber door molding, door, and most of the "wheel-well-dirt-skirt".
Once all of the quarter panel bolts were exposed, "the painted bolts" I removed all but one bolt in the top middle. The last bolt to remove is inside the panel, "the crux" bolt requires a reach trough of the dirt skirt, and a blind socket to bolt connection to remove. Once the interior painted bolt has been unscrewed, I removed the last bolt on the top, then carefully popped the entire panel off.
I took the panel inside and laid it on the carpet, I peeled off the OEM Wildtrak sticker, and put it on sticker paper for later use.
I used blue painters tape to get a good idea of where to place the emblem. using a piece of thin cardboard, I created a template of where the holes would need to be drilled. I confirmed with a bubble level it was sitting on the right plane, then used a sharpie to mark some dots.
I held my breath, and drilled, drilled again, and again, poking 5 holes in my flawless race red panel. I finished drilling, and by the grace of god, the emblem fit perfectly. I snapped the back side connector-clips on, and paraded the quarter panel through my house.
Putting everything back together was fairly painless.
I'm stoked on the results!
