Reverse Lights
JesseS
Jesse
Northern California
Jayco AY26, Honda F6B, CR-V
Just remember that adding hi-power LED lighting will in most cases overload the stock wiring & fuse. Best to run a dedicated power wire to a relay tripped by the stock power lead, so the lights get full power. I have a 100,000 lumen light that would ligh up the Grand Canyon (OK, slight exaggeration)but draws 15 amps.
Bodge Garage
Kris
Millwood WA
1994 Land Rover Discovery, Jeep Gladiator
There are a 100 ways to achieve good lighting. You do need super high power lamps. I have a pair of these cut into my bumper. They pull like an amp at best and are way more light than I need. I swapped LED's for the factory incandescents and the combined load of all 4 LED's is less than stock. The Bronco will be different but it is a simple add.
Ford Bronco Reverse Lights IMG_20200704_101800_926
Ford Bronco Reverse Lights IMG_20200704_101800_927
mrcx
Grapevine, TX
'67 Camaro
I'm sure there will be some aftermarket bumpers that integrate the rear lighting. This is what I had on my Jeep. I wired them to come on when I put it in reverse.
Ford Bronco Reverse Lights 1604464364069
snoopcat
Kentucky
70 Ford Mustang, Mazda CX5
The reverse lights on Ranger with the BLIS package (LED tail lights) are quite bright, great dispersion and do an excellent job of lighting the area where the camera captures.
I am expecting the LED tails on Bronco to also be excellent as they appear to be comparable LED configuration for the white (reverse) section.
The big question is will we get these lights on the mid package Black Diamond?
csj
Craig
17 Tacoma OR
Personally I think round aftermarket lights, white tops, and large tires and lifts look 1970's and ridiculous, to each his own.
FWIW, I live in the bay area, at night there's always some lights on. I just got back from a short trip to the Sierra mountains, I forgot how dark it is with zero lights on outside. Maybe some of you have better natural night vision than me, but I found the rigid lights added to the front and back of my truck helped tremendously. I wouldn't want to be out in the boonies without them.
MarkusBigBucks
Markus
Port Orchard Washington
2000 Ford Superduty 7.3 PSD, 2017 Ford Escape.
https://www.4x4truckleds.com/2021-ford-bronco-reverse-kit-w-baja-designs/
This is the route I went as it works with reverse or uplifter switch. If money is no object this is what I would do.
Now if money is of concern I would go with Hella Value fit
4SQ 2.0, we use these on our semi trucks and we have no problems with them, $40 each, they are bright, spot and flood, after 200k miles of driving at night only in the PNW in the shadow of the rain forest of the Olympic mountains they have not leaked or burned any of the leds out. I actually just bought 2 for my pickup truck.
They are very bright, I actually made a video of me turning them on I sent to my brother, I will try to attachit , you can see how bright they are.
file to big, ill see if i can shorten it
only way is to make it very very short , I had to cut out the shot of my milage .
Edit number 4, the movie is there but doesnt seem to play not sure why.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
I'm trading in my 2009 F-150 for this Bronco whenever Ford sees it fit to delivery it to me. Question I have is, my truck reverse lights were(are) TERRIBLE. I ended up purchasing a "White Night" reverse lights kit that mounts around my trailer hitch and turns on when I out the vehicle in reverse. It's been good but it looks pretty outdated and sorta tacky. I'm not a big light bar guy, I don't really like the aesthetic.
What other options are out there that are more modern looking and will:
A. Look Decent
B. Perform Well
C. Power on automatically when in reverse
D. Last
Thanks,
Cliff
Edit: price is not a concern
You can do the Baja Designs kits... 2 options
1) This kit attaches to the spare tire. It's a bit more "out there" in terms of styling:
https://www.4x4truckleds.com/baja-designs-reverse-kit-for-2021-ford-bronco/
(The license plate bracket is optional)
Ford Bronco Reverse Lights 1634578519895
Another option, still using Baja Designs lights but we put together a kit that puts the lights under the bumper. Out of the way, note as noticeable and my preferred method (as I want them low and not screaming "hey look at me!!!")
Ford Bronco Reverse Lights 1634578569056
With the 2nd kit, this taps into your reverse lights automatically so when you go in reverse, they come on (you can also turn them on from a switch as well)
Lindy08
Lindy08
Cliff
Illinois
2009 F-150
That’s second kit is pretty slick!
EcoBco
Kevin
SE Michigan
I see for the bumper mounted option there is a harness for tapping into the reverse circuit. Is this also available for the spare tire mounted kit?
daddycreswell
Josh
Tenneessee
2013 Raptor, 1973 Bronco
I have plans to do what I did to my Raptor, cut the bumper and install a pair of cubes on each side of it and wire them to the reverse lights. If there is room, if not I think I will mount to the top of the rear bumper.
Exomodo
Ryan
Marquette, MI
Ranger
If you are ordering the tow package, the 7 pin connector will have a reverse (BU), ground (GD) and 12 volt battery source (AP), you could wire in a light package on these circuits for something with no manual engagement...
Ford Bronco Reverse Lights SchmTRL
802Bronco
Southern Vermont
2016 XLT F150 Crew, 1999 Ranger, 2002 Mastercraft
I understand that, I’d rather not have to flip a switch every time I want to reverse.
I also have no experience with LED tail lights, so, I’m hoping they are bright.
I agree with wiring to an auxiliary switch. What I didn't see mentioned was that you can tap into the reverse light circuit AND wire them to an auxiliary switch so you can turn them on even if you aren't in reverse.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
802Bronco
Southern Vermont
And now I've noticed they sell kits that do all that for us.
