Roof Rack
alnightr
Doug
Kansas City MO
Explorer ST
Looks like you can get a roof rack with the Sasquatch! Oh unless you want the 2.7 V6 engine. Go figure. Looks like an aftermarket
one. Makes no sense
pakrat
JG
Lake Tahoe
Toyota 4Runner-F250-Tundra
Jeez. So the problem wasn't really solved and no definitive answer from anyone why they can't put it on the 2.7 sasquatch.
I know everyone keeps saying GVRW but common, a couple cheap and light roof rails really are going to put you over the limit? Scary shit if it is some kind of roll over concern. If that's the case nobody should ever be using those racks on any model.
alnightr
Doug
Kansas City MO
Explorer ST
Also if you want the cargo area mat you can’t have the Sasquatch package! 😳
2100
If yinz know yinz know
dodge charger
Can't have the body armor with squatch either. Can't have the fold out table with Badlands. I'm sure there's plenty more
BigSteveO
Stephen
Maine
Subaru Outback
one. Makes no sense
Somehow I made it work :unsure:
2022 Bronco BADLANDS™
SUMMARY
SavePrint
EXTERIORS4Edit
  • Eruption Green Metallic Paint$0
  • 17" Black High Gloss-Painted Aluminum with Warm Alloy Beauty Ring, Beadlock Capable Wheels$0
  • 315/70R17 Mud-Terrain (M/T) Tires (35")$0
  • Hard Carbonized Gray, Molded-in-Color (MIC)$0
  • Full Vehicle Steel Bash Plates$0
  • Roof Rails with Crossbars $365
  • Headlamps – LED with LED Signature Lighting $0
    INTERIORS4Edit
    • Black Onyx $0
    • Marine Grade Vinyl Seats – Black Onyx $0
    • Auxiliary Switches in Overhead Console with Front Map Lights $0
    • Storage Bag – Front Row Top Panels
    • Hard Top Sound Deadening Headliner
    • SNC®4 with Enhanced Voice Recognition (Mid Package)
    • 10-Speaker including Subwoofer B&O® Sound System by Bang & Olufsen® with Connected Built-In Navigation (Lux Package)
    • 12" LCD Capacitive Touchscreen with Swipe Capability (High Package)
    • SiriusXM® With 360L
    • Connected Built-In Navigation
      POWERTRAINSS4Edit
    • 2.7L EcoBoost® Engine $1,895
    • Advanced 4x4 with Automatic On-Demand Engagement
    • 10-Speed SelectShift® Automatic Transmission
    • Rear Locking Differential
    • 4.7 Locking Rear Axle Final Drive Ratio
    • PACKAGESS4Edit
      Lux Package (334A)
      $5,085
      • Sasquatch™ Package $4,090
        Contact Dealer
    • PRICING SUMMARY
      • BASE MSRPS1
        $47,580
      • OPTIONSS4 & ACCESSORIESS8
        + $6,350
      • DESTINATION CHARGESS17
        + $1,495
      • TOTAL MSRPS16
        = $55,425
      • ESTIMATED NET PRICES5
        = $55,425
wanna1
Andrew
2013 Ford F150 Platinum 4x4 2022 Mach E
Is that a 2 door?
Broncie
Joseph
2013 Honda Accord Coupe
Is that a 2 door?
I just built my 2 door badlands sasquatch with roof racks and the 2.7 engine to send to my dealer to order, so it must be a weight thing with the 2 door that allows it.
wanna1
Andrew
Right. It won't add on a 4 door unless you go to the 2.3.
Corsair
Jacob
San Francisco
Escape
Yeah, same with the 2021.
lakesinai
Charleston SC
one. Makes no sense
So, if you look at pg. 12 of the Bronco Equipment Installation Guide (posted today on Bronco Nation), theres a table on Roof Rack Load Capacity:
In motion: 110lbs
Stationary: 450lb
315/70R17 tires: 0
An Explanation: If you look at the specs on those Goodyear Territory tires, you'll see that they are the softer "C" rated tires, with weight capacity of a measly 2535 pounds! Thats weak for a loaded vehicle. But that explains the capacity issue, ITS THE TIRES! A fix would be to upgrade to an E rated tire, get a rack, and move on.
Ford Bronco Roof Rack SmartSelect_20211016-093314_Driv
da_jokker
Jeep Wrangler JKUR
WT solves those problems.... Just saying 😁
JohnnyBronco
Pennsylania
X4
Brings back memories of the Honda Element my son had with a net cargo weight of 850# .
That meant a driver and 3 passengers that averaged 200# each could carry a duffle between them of only 50#
Some of the things, like the tailgate table and cargo mat are available through accessories so Ford would be almost clueless you add these extra weight items to your vehicle, unless you use points to buy.
BadSquatch21
PA
Land Rover and Porsches; '22 Mansquatch
In motion: 110lbs
Stationary: 450lb
315/70R17 tires: 0
This is the dumbest thing I've seen in awhile. So they'll let you get the roof rack but if you put a pair of skis up there and get in an accident, technically someone could prove you've overloaded your vehicle? Seems like a lawsuit waiting to happen for Ford.
