Could be true...but. The 3.0L Ecoboost is an aluminum block...the 2.7L is a compacted graphite iron block (AKA Diesel engine block material). I know that for a small block engine with twin boost I want the compacted graphite block..
We debunked this back in June of last year. The 3.0 is CGI just like the 2.7, the Car and Driver/Ford Authority/Wikipedia entries are wrong.I guess the 3.0 EcoBoost is based on the 2.7 block, except the 3.0 is cast aluminum vs the compacted-graphite iron for the 2.7, based on this article. It appears 2.7 was designed for more heavy duty or truck applications vs the 3.0, which powers the current Lincoln line up.
https://www.bronco6g.com/forum/threads/another-v6-option.1518/page-3#post-46096
And by now we have people wrecking Explorers, so take a look at the 3.0 engine:
What's that peeking out from behind the aluminum ladder structure? CGI!
You have the NA 3.5 in your Edge, the Edge never got the 3.5 EcoBoost.I have the 3.5 in my Edge. I hope this is true!
Also I keep having to post this over and over again when people fetishize the 3.5 EcoBoost, but the 3.0 EcoBoost is the good one. The 3.5 is an NA engine converted to turbo, the 2.7/3.0 were built from the ground up for boost. Significantly stronger, more durable, and capable of making much more power. I would absolutely trade a half liter of displacement for a partially closed deck, CGI bore structure, offset rod caps, steel band insert pistons, and more. The 3.0 is the one you want.
