So the Sasquatch tire is the new Goodyear Territory MT.
This tire is already available in 265/60/20 on Tire rack for a wight of 42 lbs in Load C range.
The popular BFG KO2 are only available in E load range for this size, at 57 lbs.
However, I could compare 2 KO2 of the same size (285/70/17) in both C and E range to see approximately how much E range adds in weight. The answer is 7lbs so we can safely assume a KO2 in 265/60/20 would be about 50 lbs.
What that all means is that a Goodyear Territory MT would be approximately 20% lighter than the exact same (size and load) KO2. Very good news if true.
Of course this relies on Tirerack spec accuracy. But I am sure the Territory will be soon available in 35" anyway because the TRX is out and uses those.
