The tailgate table if you are competent with a drill and can be careful can also be done. Just make sure to use a drill stop tape or a short bit. The nutserts can be tricky to put in. You can tap the outside if the gate if not careful or the bit draws itself in too fast.
The OP is better off installing the tailgate table so it can be done correctly.You prob don’t want them installing the back door fold down table I’ve seen people post there dealers drilled to deep making a hole in the back swing door
When you buy the tailgate table, it comes with the drill bit and a collar with a set screw so you do not drill too deep and hit the outside skin of the tailgate. The knuckleheads at the dealerships either are not reading the instructions or do not care.
