Spare tire delete fans - this looks good -
JesseS
Jesse
Northern California
Jayco AY26, Honda F6B, CR-V
Ratchet strap uses part 2.
When using a high lift jack the suspension will droop too much sometimes where you can't get the wheel/tire off.
Wrap the ratchet strap around the frame and axle before jacking it up so the axle comes up with the vehicle.
Good idea, but not new, I used one to hold the forward tandem axle off the ground when the tire blew and I was already using the spare..... that was a fun day.
Halfsmoke00
Kenny
Illinois
'09 Ford Escape AWD V6, '91 Plymouth Acclaim V6
I don't need a spare tire delete kit as much as I want a heavy duty swing out tire carrier with jerry can racks behind the tire, like you can get for a Jeep.?
I have a ACE heavy duty tire carrier on my Jeep. Has the 2 rotopak mounts and a spot for either a jerry can or hi-lift jack.
These may be essential just for the extra fuel capacity alone considering the small gas tank on the 2 door.
Cappy
Cappy
North Texas
2021 Ford Ranger
No thanks. I’m keeping my spare. Have fun being stuck on the side of the interstate waiting for AAA.
Deleting the rear tire mount, doesn't necessarily mean deleting the spare.
NotApplicable
BEVs
andrusoid
Steven
Bend, Oregon
2017 Outback, '79 2G, '89 3G, '92 5G White!
So, exposed door vents, a wire plug, no backup camera, and no third brake light? Ok. Good luck with that. ?
I'm with this guy. What? Spare behind the second row seats? No spare? Lower it and cruise with yer homies?
(I do have to say I"ve seen a no-roof '72 lowered Blazer, black, red diamond quilt leather interior that totally killed it for $32k a few years ago.)
Broncola
Hawaii
Element, ‘75 Bronco widow
So replace a hole with a hole? I prefer the stock rear license plate location. Would like to see more options from other manufacturers.
Ford Bronco Spare tire delete fans - this looks good - AD5A3358-2FE7-4B1F-96FD-DBAB1B3942F1
jwcalde13
Josh
Costa Mesa, CA
2021 Bronco Badlands Sasquatch , 2022 F250 Tremor
I'm looking for an oem take off spare tire carrier if anyone has one. Please message me. Thanks!
HotdogThud
mk6 gti, '21 MoarDoor
So - this picture looks pretty good for us spare tire delete fans....
looking at this pictures makes me now know exactly how I got the giant paint defect from the factory on my bronco's rear driver's door.
How hard are they swiping things against those protective sheets there? jfc.
H - 2 CHARLIE
CHARLIE
So cal.
F 150 - E 350
A small creole bush gave me my first flat off road and after taking to a few guys in my club them bush's got them a few times weather Ko's or Kevlar tires them bush's will take the tike out . I carry a plug kit and slime air can with a air compressor jump starter but going to get me a real portable air compressor soon .
Roger123
Roger
VA Beach, VA
Not every trip is to the middle of nowhere, but without a spare you probably shouldn’t be going to the middle of nowhere at all... and then what’s the point of owning a bronco?
Obviously there are other work arounds for being out of spares... this year I was surprised with two flats on one drive within 20 miles of each other, had to pull my bike out of my truck and ride the final 45 miles home.?
You should have had a plug kit instead of a spare, would have saved you a 45 mile bike ride.
