SPD Downpipe Install - review
Edsasso
Ed
Jupiter
2022 badlands
So I got my pipes thanks to Lethal and SPD. The pipes are super nice, the welds are super nice, Quality is super nice everything is 100%. The install was no problem at all.
Some of the things I did to make the install easier:
1. I cut the factory pipes in two places, you will see where to cut because it is very intuitive if you are doing the work yourself.
2. I removed the driver side wheel well because getting to the inside turbo bolts on both sides was a pain driver was about impossible. Make sure that you have a ton of extensions, wobbles and universals.
3. I had to climb on top of the motor to disconnect the O2 sensors. I removed the factory pipes with the O2 sensors installed
4. I installed the new pipes with the O2 sensors OFF for two reasons..... The passenger side will not go with the sensor in place and 2, I didnt want to damage the sensor.
5. The V-bands make everything go together very nicely
6. The heat shield from SPD is in the perfect spot BUT still very close to the oil pan
This took me about 2 hrs.
I have noticed two new rattles.
1. my borla tips are now hitting the bumper - this may be due to the SPD flex joint that is FAR SUPERIOR to the OEM flex joint, but I dont think it flexes as much as the OEM and I also dont think it grows / shrinks the same. I may need to cut a 1/2" off my borla....
2. I dont know where the other rattle is..... Might be in the CAT? may go away..... Who knows...... High performance and modified vehicles make noises...
Sound is nice, not a ton of difference over stock, but Im sure the flow is much better. I have a Borla axel back touring system and I can tell you it is louder, but not by much and as other posters have mentioned, at some RPMS, it may be quiter or the same. I performed the warm up procedure and all is well. The pipes are nice and Im happy. Im sure I will see a much quicker spool up time when I receive my charge pipes.
All in all, If your looking for all the performance you can get, add these to the list.
Cobrafang
Thomas
GA
Love mine also. I have the AFE cat back and well not sure the wife will drive it now....mine is definitely louder.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Very nice!
Ground_zero298
Scs michigan
If you feel it’s sluggish in the low/mid power band you may want to look at a bigger muffler. My Afe was choking it out. Went up to a bigger magna flow and fixed that issue.
I had made a real nice install thread the admin deleted from here. Not sure if it was the cutting of the pipes or the warranty void. Either way your going to love them. They make a world of difference.
Mrt ran the numbers for flow and proper muffler for me. They recommended the bigger magna flow. Still has the deep sound. Just better flow, no metal ting in the top end now.
Mines mid mounted.
Ford Bronco SPD Downpipe Install - review 79EE0670-E7AB-4552-BE59-10E39614E10B
Ford Bronco SPD Downpipe Install - review FB170E8C-3E9E-43C4-B33D-7445D74D1466
MWILD
Central North Carolina
2021 Base/2DR/2.3/MT & 2023 Model S Plaid
Any idea what kind of HP and TQ gains are we seeing with this installed?
LethalPerformance
South Florida
www.lethalperformance.com
Thanks for your business and the awesome feedback!
Defyfate11
Jaime
Clovis, CA
2020 Camry TRD
Mines mid mounted.
Wouldn't the AFE have been a straight-through design? Was it the Apollo series?
Ground_zero298
Scs michigan
0fg. I thought the same. Truck ran weird with it. Just didn’t feel right in the mid power band, was really flat. It works fine with it as a exhaust tip. Go figure.
Dmorty217
Derek
Venice FL
Camery
Spd told me yesterday they have half a dozen other products to develop before they make a downpipe for the 2.3… very disappointing to say the least
CatMonkey
Lafayette LA
2023 Bronco, 2012 Shelby GT500, 2021 Shelby GT500
I hope to do my SPD install this week. I don't really want to cut the factory pipes out of there. Did you try to get them out intact first?
Ground_zero298
Scs michigan
I’ve heard it can be done. Have to drop the whole cross member. I was working off one jack stand so I cut the exhaust instead.
James Cole
MX
Badlands Sasquatch (hopefully)
Are you still getting rattles? Also hows power and turbo spool?
Thanks!
JC
Edsasso
Ed
Jupiter
2022 badlands
Thanks!
JC
I think I got the rattle fixed found. Looks like I over tightened the flange to the mid pipe and exhaust was leaking out of the multi layer gasket. I loosened the bolts and it seems to be better. I’ll know tomorrow. If it still makes noise, I will replace the gasket. Yes everything is faster. Very impressed. I need a mid pipe next or cat back, but I already have an axle back.
James Cole
MX
Great, let us know how it works out... also is the install hard?
Edsasso
Ed
Jupiter
2022 badlands
I will. No not bad. They fit perfectly
